| | Vista 64bit - Adminstrative Tools MMC using 64bit? I was poking around and noticed the following: Administrative Tools > Services (%SystemRoot%\system32\services.msc) However the following exists as well: (%SystemRoot%\SysWOW64\services.msc) So, is Vista 64 by default using the 32bit versions, or are the 64bit version in system32 as well? Note: When I run both neither have the "*32" which I'm assuming is a flag for 32bit support. Needless to say I'm a little confused. |
| | Re: Vista 64bit - Adminstrative Tools MMC using 64bit? Did you install any 64-bit third-party programs that can take advantage of a sophisticated 64-bit operating system? -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows System & Performance --------------------------------------------------------------- "null" wrote: I was poking around and noticed the following: Administrative Tools > Services (%SystemRoot%\system32\services.msc) However the following exists as well: (%SystemRoot%\SysWOW64\services.msc) So, is Vista 64 by default using the 32bit versions, or are the 64bit version in system32 as well? Note: When I run both neither have the "*32" which I'm assuming is a flag for 32bit support. Needless to say I'm a little confused. |
| | Re: Vista 64bit - Adminstrative Tools MMC using 64bit? System32 has the 64bit version. And it is what is used. Even if you run the one in SysWOW64, you actually end up with the 64-bit one. -- Charlie. http://msmvps.com/xperts64 http://mvp.support.microsoft.com/profile/charlie.russel "null" <null@xxxxxx> wrote in message news:B6C31153-7739-4F48-89BE-6D9A0A73EA20@xxxxxx Quote: >I was poking around and noticed the following: > Administrative Tools > Services (%SystemRoot%\system32\services.msc) > > However the following exists as well: (%SystemRoot%\SysWOW64\services.msc) > > So, is Vista 64 by default using the 32bit versions, or are the 64bit > version in system32 as well? > > Note: When I run both neither have the "*32" which I'm assuming is a flag > for 32bit support. > > Needless to say I'm a little confused. > > > > > > > > |
| 64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions | General Discussion | |||
Unable to install 64bit NVidia drivers on Vista 64bit | Drivers | |||
| Vista Premium 64bit to Ultimate 64bit Upgrade Fails | Vista installation & setup | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
Does 64bit machines (Dual Processors) need a 64bit Vista? | General Discussion | |||
