Vista - Autorun problem
Old 04-02-2008   #1 (permalink)
Donato
Autorun problem
Hi, my question is: when I turn on my computer and windows vista runs on the
desktop appears the autorun properties dialog. Every time I run my system is
always the same. Is this a problem? I thinks so, because some days before
this didn't happen, so what can I do to solve this?? Thanks. Donato
Old 04-02-2008   #2 (permalink)
Mark L. Ferguson
Re: Autorun problem
This may help explain what is going on. It works the same in Vista.
310560 - How to Troubleshoot By Using the Msconfig Utility in Windows XP:
http://support.microsoft.com/default...b;EN-US;310560
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Donato" <Donato@xxxxxx> wrote in message
news:9458C689-EAED-4D2E-BD8C-1DDE8B525885@xxxxxx
> the
> is
CD autorun problem Vista installation & setup
A problem with autorun Vista performance & maintenance
VISTA autorun problem Vista installation & setup
autorun problem with VCDs Vista General
slight problem with autorun Vista General
