Vista - System Restore problem
Old 04-05-2008   #1 (permalink)
Billinares
Hello.
I cannot get the System Restore to work! Whenever I try the computer seems
to be doing its thing, but after re-star a message appears saying that it
was not able to carry out the System Restore due to an unknown problem.
That's it! I run Vista Ultimate on a new computer as administrator. I have
turned off the Windows Defender.
Can anybody help?
Thanks
Old 04-05-2008   #2 (permalink)
Mark L. Ferguson
Re: System Restore problem
Here are some troubleshooting steps to take when System Restore fails to
restore: http://bertk.mvps.org/html/srfail.html
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Billinares" <billinares@xxxxxx> wrote in message
news:C0CC37EA-5AF6-4A10-AF16-A3EBAE63ADA2@xxxxxx
Quote:
> Hello.
> seems to be doing its thing, but after re-star a message appears saying
> that it was not able to carry out the System Restore due to an unknown
> problem. That's it! I run Vista Ultimate on a new computer as
> administrator. I have turned off the Windows Defender.
> Can anybody help?
> Thanks
Old 04-05-2008   #3 (permalink)
ove1
RE: System Restore problem
This happened to me also with Vista Ultimate SP1. I was able to do the
restore by first rebooting into safe mode. I believe the problem was caused
by my antivirus "self-defense" mode. I updated Avast antivirus to the latest
version (4.8) and that appeared to fix the problem. I noticed that in Avast
settings, troubleshooting, that there is now a check box to disable
self-defense. I suspect that other antivirus programs have similar settings.
"Billinares" wrote:
Quote:
> Hello.
> Can anybody help?
> Thanks
Old 04-06-2008   #4 (permalink)
Billinares
Thank you. It was.
"Mark L. Ferguson" <MarkLFerguson@xxxxxx> schrieb im
Newsbeitrag news:FDF3B0C3-2316-430A-B066-F9308117EC6A@xxxxxx
> interface.
> Mark L. Ferguson
system restore Problem General Discussion
System Restore Problem General Discussion
System Restore problem Vista General
problem with system restore Vista General
System Restore Problem? Vista General
