| Vista Home Premium | System Recovery Help After doing a system recovery on my computer the storage space seems to be almost all the way used up. This computer contains Vista Home Premium in the hard drive. What can I do? |
| | Re: System Recovery Help More information is needed to answer your question. Read one or more of the below links then post back. [How to ask a question] http://support.microsoft.com/kb/555375 How To Ask Questions The Smart Way http://www.catb.org/~esr/faqs/smart-questions.html Good Post http://66.39.69.143/goodpost.htm "sylviafrb" <sylviafrb.37i5e1@xxxxxx-mx.forums.net> wrote in message news:sylviafrb.37i5e1@xxxxxx-mx.forums.net... Quote: > > After doing a system recovery on my computer the storage space seems to > be almost all the way used up. This computer contains Vista Home Premium > in the hard drive. What can I do? > > > -- > sylviafrb |
| Vista Home Premium | Re: System Recovery Help Thank you. I previously had a problem on my Gateway Laptop Computer - Intel Core2 Duo Centrino, that came pre-installed with Windows Vista Home Premium, which I could not fix. I had to do a System Recovery using the on-screen program and did not back up any of my files, in attempt to clear out everything that I had on the computer. After I completed this process, I set up my desktop and internet, and started over. When reviewing my Hard Disk Drives on my "Computer" menu, I notice that my C: Drive is almost all the way full (8.55 GB free of 139 GB). Although I downloaded a few programs and set up my Internet Security, I am sure I did not install anything large enough to use up almost all of the computers storage space for programs and files. By doing the System Recovery I thought that it would erase everything so that my computer would be back to it's factory condition. Could my previous files still be in the computer? After searching this forum, I did not find any information on the specific question that convinsed me of the soultion, or a course of action. Can anyone help me? |
| | Re: System Recovery Help You should have 2 partitions, one of them being the Recovery partition: approx 8.5G. Contact Gateway. -- Mick Murphy - Qld - Australia "sylviafrb" wrote: Quote: > > Thank you. > I previously had a problem on my Gateway Laptop Computer - Intel Core2 > Duo Centrino, that came pre-installed with Windows Vista Home Premium, > which I could not fix. I had to do a System Recovery using the on-screen > program and did not back up any of my files, in attempt to clear out > everything that I had on the computer. After I completed this process, I > set up my desktop and internet, and started over. When reviewing my Hard > Disk Drives on my "Computer" menu, I notice that my > C: Drive is almost all the way full (8.55 GB free of 139 GB). > Although I downloaded a few programs and set up my Internet Security, I > am sure I did not install anything large enough to use up almost all of > the computers storage space for programs and files. By doing the System > Recovery I thought that it would erase everything so that my computer > would be back to it's factory condition. Could my previous files still > be in the computer? After searching this forum, I did not find any > information on the specific question that convinsed me of the soultion, > or a course of action. Can anyone help me? > > > -- > sylviafrb > |
| How to creat recovery partition with recovery image in vista to restore the system | Vista installation & setup | |||
| System Recovery...please help... | General Discussion | |||
| Cannot get to system restore points after doing a system recovery | Vista performance & maintenance | |||
| Reinstalling the system recovery files made just before system rec | Vista installation & setup | |||
| system recovery dvd | Vista installation & setup | |||
