| | Laptop Cooling Fan Hi: I have a Toshiba Satellite P105 laptop and recently updated the bios (as advised by a Toshiba bulletin). I also installed a newer version of my internet security suite (on the same day) and have noticed my laptop is now getting warmer than it was before either of the updates. I have a laptop cooler attached and prior to either updates the internal fan never kicked on and I never felt heat coming from the laptop. Now I have noticed the keys of the laptop are warmer (not uncomfortably so, but noticeably warmer) and the internal fan now turns on intermittantly. I have also noticed an increase in CPU usage with fewer applications open (idle still remains between 0-4%). Could the increased heat be caused by the software either of the software updates? And how can I check my bios version and if I wanted to revert back to my previous bios version how would I do that save restoring with the factory disc? Thanks! -- Check out the great stores listed here! Receive special offers! Visit http://driven.mysite.com |
| | Re: Laptop Cooling Fan Before replacing the BIOS you need to be sure it's not your anti-virus app running more. Turn it off to test that. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "tempting2taanzaa" <taanzaa39@xxxxxx> wrote in message news:8517937F-0E13-4D9C-8A09-FD9BEBBCA50E@xxxxxx Quote: > Hi: > > I have a Toshiba Satellite P105 laptop and recently updated the bios (as > advised by a Toshiba bulletin). I also installed a newer version of my > internet security suite (on the same day) and have noticed my laptop is > now getting warmer than it was before either of the updates. I have a > laptop cooler attached and prior to either updates the internal fan never > kicked on and I never felt heat coming from the laptop. Now I have > noticed the keys of the laptop are warmer (not uncomfortably so, but > noticeably warmer) and the internal fan now turns on intermittantly. I > have also noticed an increase in CPU usage with fewer applications open > (idle still remains between 0-4%). Could the increased heat be caused by > the software either of the software updates? And how can I check my bios > version and if I wanted to revert back to my previous bios version how > would I do that save restoring with the factory disc? > > Thanks! > > -- > Check out the great stores listed here! Receive special offers! Visit > http://driven.mysite.com |
| Fan cooling | Overclocking & Cooling | |||
| Cooling a 9800GX2 | Graphic cards | |||
| Cooling BallistiX | Overclocking & Cooling | |||
| What cooling PAD Should i choose? | General Discussion | |||
| Cooling fan on Toshiba laptop | Vista hardware & devices | |||
