Vista - Annoying "Flicker" Problem
Old 04-10-2008   #1 (permalink)
Island Momma
Got this dang computer (HP) with Vista Home. It drives me nuts. When I am
typing it suddenly does something (maybe called a flicker) and the curser
ends up somewhere else on the page.... (and the letters get typed out of
place)
I have my monitor set for 1024 X 768, I tried to raise the Monitor setting
screen refresh rate, but it is set at 60 Hertz and there is no other option
for it. If I increase the pixels there is still only 60 Hertz setting
option.
What is this problem and how can I get it fixed. Getting tired of screwed
up text .
Thanks for any help anyone can give me!
Marianne
Old 04-13-2008   #2 (permalink)
sasman
RE: Annoying "Flicker" Problem
Is there anyone out there with a solution to this issue. I have a Tohsiba
purchased 1 year ago (running Vista), and had this isue, but being a computer
novice, always assumed it was something I was doing. However, just bought my
spouse a new Acer (again, running Vista) and having the same issue on that
one, so I decided to do some research. It has to be a Vista issue since it is
occurring on 3 different computers being used by 3 different people.
Pleeeeease, if someone out there has a solution for this, can you post and
help us out.
> place)
> option.
> up text .
> Marianne
Old 05-10-2008   #3 (permalink)
JUBOO
> place)
> option.
> up text .
> Marianne
Old 05-10-2008   #4 (permalink)
Falcon
Re: Annoying "Flicker" Problem
>> place)
>> option.
>> up text .
>> Marianne
Is it a laptop? If so your palms are brushing the touch pad and
moving the cursor. Either disable the touch pad and use a mouse or
be more careful about the pad.
Ciao,
Falcon
Old 05-10-2008   #5 (permalink)
JUBOO
i have had vista for a year and this just started happening to me.
It is driving me crazy!!! It happens in email, word, online everywhere.
Even typing this took a couple of trys. HELP
> help us out.
> > place)
> > option.
> > up text .
> > Marianne
Taskbar flicker when set on "autohide" Vista General
Vista "Start menu > Programs" annoying to organize Vista file management
Annoying "Flicker" Problem written 4/10/08 by Island Momma Vista General
Eliminating the annoying "Startup programs blocked" popup message Vista General
Annoying message popping up "Windows has stopped some start up programs" Vista General
