| | #11 (permalink) |
| | Re: System Restore Problem Quote: Quote: > > "stevehaz_uk" wrote: > > Quote: > > > > > > To get system restore working apply the registry patch below... tested > > > > > > 'RapidShare: 1-Click Webhosting' > > > (http://rapidshare.com/files/106723046/SRFix.rar) > > > > > > > > > -- > > > stevehaz_uk Quote: Quote: > > Steve, OK, got the .reg file merged via regedit->import but SR still doesn't work!!!! BTW, i'm running Vista SP-1. Ray ![]() |
| | #12 (permalink) |
| | Re: System Restore Problem On Thu, 17 Apr 2008 14:50:02 -0700, Athanasian Creed <>< <Athanasian Creed <@discussions.microsoft.com> wrote: Quote: > > >"Donald L McDaniel" wrote: > > Quote: >> Try, friend: >> Control Panel/System/System Protection Tab >> >> >> You MUST turn off System Restore for EACH physical drive there are >> restore points on. >> >> Donald L McDaniel >> Please reply to the correct thread and article. >> ================================================ > >Donald, > >Tried that several times, each time it hangs on 'analysing disks'. System >Restore & create restore point buttons inoperable. > > > >Ray ![]() Donald L McDaniel Please reply to the correct thread and article. ================================================ |
| system restore Problem | General Discussion | |||
| System Restore Problem | General Discussion | |||
| System Restore problem | Vista General | |||
| problem with system restore | Vista General | |||
| System Restore Problem? | Vista General | |||
