Network speed is half or one third of speed on XP
  1. #1
    power 3 Guest
    I have a desktop dual boot with XP and VistaSP1
    and a laptop with XP,
    when I move files from XP to XP via network the speed os fast
    when I move files from XP to Vista and vise versus, the speed is half to
    one third of when Im runing XP
    Why is this and how can I fix it...
    I have tried disabling firewalls and antivirus on both machines with no
    effect..
    something is fishy with the vista network..
    Please advise
  2. #2
    power 3 Guest
    Re: Network speed is half or one third of speed on XP
    Canuck57 wrote:
    > "power 3" <power@xxxxxx> wrote in message
    > news:47fe30ee$1@xxxxxx-privat.org...
    >> effect..
    >> Please advise
    > Have you applied SP1? It helps a little. But like you, I can't get Vista
    > to copy files disk to disk or network to disk like XP. Vista has issues
    > here.
    In my post I say "VistaSP1", so yes I have sp1
    Even with SP1 its slow, and as you I have noticed the disk speed is
    slower than with XP.
    Any solutions anyone? I have the very latest drivers for everything so
    its not a driver problem.
    If I disable the IPv6 protocol will that do anything to help?
    ANy other ideas?
  3. #3
    KDE Guest
    try this:
    On 24 Mar, 19:22, jdr.sm...@xxxxxx wrote:
    > > >....speed improvement in
    > > > file operations by disabling Remote Differential Compression. Control
    > > > Panel| Programs and Features|Turn Windows features on or off|Uncheck
    > > > Remote
    > > > Differential Compression. I have found no negatives to disabling RDC.
    > > > Hope this helps.
    > effect..
    > Please advise
  4. #4
    DanS Guest
    power 3 <power@xxxxxx> wrote in
    news:47fe4ec6$1@xxxxxx-privat.org:
    > ANy other ideas?
    Disable the on-board NIC and use a different brand NIC.
    Vista should have drivers for the tens of semi-generic NICs out there.
Network speed is half or one third of speed on XP problems?
Every App and Vista itself runs at only half the speed Stefan Vista General 15 03 Dec 2007
Modem speed is half SeanV Vista networking & sharing 5 11 Feb 2007
Modem is half speed! crap! SeanV Vista General 6 02 Feb 2007
Modem is half speed! DAMN! SeanV Vista General 5 02 Feb 2007
Athlon 64 stuck at half speed under Vista Roof Fiddler Vista performance & maintenance 4 16 Sep 2006
