| | System Restore not working I have a recent problem installing Windows updates on Vista Ultimate as the update process stays on 'creating restore point' forever. I've let it run as long as 7 hours in this state, with no change. It looks like the system is unable to make a restore point sucessfully. I know it has worked in the past, as I'm fairly up-to-date on Windows updates. Reading some other threads, I've tried using Disk Clean-up to remove all by the most recent restore points, and then try to disable/re-enable system restore - this part without success. When I check the system properties for System Restore, the System Restore button is greyed out. I've attached a screenshot of the screen for reference. I've checked the group policies to verify the System Restore is not disabled there. Any other places I should be checking? Many thanks, +-------------------------------------------------------------------+ |Filename: System Properties.jpg | |Download: 44 | +-------------------------------------------------------------------+ -- Vistified Posted via http://www.vistaheads.com |
| vista HP x64 | Re: System Restore not working |
| | Re: System Restore not working Boot into Safe Mode with Networking. While in Safe Mode, manually create a restore point and try installing the updates. How to Start Vista in Safe Mode Safe Mode ------- *Report back, please* "Vistified" <Vistified.37pwk5@xxxxxx-mx.forums.vistaheads.com> wrote in message news:Vistified.37pwk5@xxxxxx-mx.forums.vistaheads.com... Quote: > > I have a recent problem installing Windows updates on Vista Ultimate as > the update process stays on 'creating restore point' forever. I've let > it run as long as 7 hours in this state, with no change. It looks like > the system is unable to make a restore point sucessfully. I know it has > worked in the past, as I'm fairly up-to-date on Windows updates. > > Reading some other threads, I've tried using Disk Clean-up to remove > all by the most recent restore points, and then try to disable/re-enable > system restore - this part without success. > > When I check the system properties for System Restore, the System > Restore button is greyed out. I've attached a screenshot of the screen > for reference. > > I've checked the group policies to verify the System Restore is not > disabled there. > > Any other places I should be checking? > > Many thanks, > > > +-------------------------------------------------------------------+ > |Filename: System Properties.jpg | > |Download: 44 | > +-------------------------------------------------------------------+ > > -- > Vistified > Posted via http://www.vistaheads.com > |
| | Re: System Restore not working So far no luck. After booting into Safe Mode, System Restore (rstrui.exe) won't run. Task Manager shows the process running, and the cpu amount changes, but no screen ever appears. Any other way to create a restore point? I should mention that this drive is a multi-boot drive, with this as the primary boot. There are two other OS on other partitions of the same drive - XP and a testing version of Vista. The test-Vista partition does not have this issue. All three OS have co-existed peacefully for several months. -- Vistified Posted via http://www.vistaheads.com |
| | Re: System Restore not working Hi Vistified, This is due to a registry based Policy. BTW, I don't see any attachments in your post. Why not use a newsreader to access the MS Newsgroup? Microsoft Newsgroup Setup Instructions for Windows Mail http://www.winhelponline.com/blog/mi...-windows-mail/ -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com Winhelponline.com blog http://www.winhelponline.com/blog "Vistified" <Vistified.37pwk5@xxxxxx-mx.forums.vistaheads.com> wrote in message news:Vistified.37pwk5@xxxxxx-mx.forums.vistaheads.com... I have a recent problem installing Windows updates on Vista Ultimate as the update process stays on 'creating restore point' forever. I've let it run as long as 7 hours in this state, with no change. It looks like the system is unable to make a restore point sucessfully. I know it has worked in the past, as I'm fairly up-to-date on Windows updates. Reading some other threads, I've tried using Disk Clean-up to remove all by the most recent restore points, and then try to disable/re-enable system restore - this part without success. When I check the system properties for System Restore, the System Restore button is greyed out. I've attached a screenshot of the screen for reference. I've checked the group policies to verify the System Restore is not disabled there. Any other places I should be checking? Many thanks, +-------------------------------------------------------------------+ |Filename: System Properties.jpg | |Download: 44 | +-------------------------------------------------------------------+ -- Vistified Posted via http://www.vistaheads.com |
| | #6 (permalink) |
| | Re: System Restore not working If there is a Registry based policy that can be changed, can someone please direct me to it? Thanks! -- Vistified Posted via http://www.vistaheads.com |
| | #7 (permalink) |
| vista HP x64 | Re: System Restore not working The little file that is in my post above (download it from rapidshare) is from Microsoft and it puts this problem right... |
| | #8 (permalink) |
| | Re: System Restore not working Can you add the link to this thread please? I'm not able to find the other message post you refer to in your note. Any other suggestions from others are welcomed as well please! stevehaz_uk;783100 Wrote: Quote: > The little file that is in my post above (download it from rapidshare) > is from Microsoft and it puts this problem right... > > > -- > stevehaz_uk -- Vistified Posted via http://www.vistaheads.com |
| | #9 (permalink) |
| | Re: System Restore not working Vistified wrote: Quote: > Can you add the link to this thread please? I'm not able to find the > other message post you refer to in your note. > > Any other suggestions from others are welcomed as well please! > > > stevehaz_uk;783100 Wrote: Quote: >> The little file that is in my post above (download it from >> rapidshare) is from Microsoft and it puts this problem right... >> >> >> -- >> stevehaz_uk Here is the link he posted: http://rapidshare.com/files/106723046/SRFix.rar It's a Winrar archive file which unpacks to a text REG file. |
| | #10 (permalink) |
| | Re: System Restore not working Thanks for the link. Unfortunately the registry entry did not change my situation - I still have the buttons for System Restore greyed out, as per the .jpg I attached in the original post. Most of the entries I've seen on the net seem to have a slightly different scenario - where they have a message that restore point creation is disabled by Group Policy. I do not have that message. Hopefully someone can point me in another direction. Many thanks. -- Vistified Posted via http://www.vistaheads.com |
| System restore not working | Vista performance & maintenance | |||
| System Restore Not Working | Vista General | |||
| System restore not working! | Vista General | |||
| System Restore not working | Vista security | |||
