| | Transparent Volume scale Hey everyone... I have Vista Home Prem with a MS 2000 keyboard that has the volume control feature on the kb.... Does Vista have a feature like Mac OSX where if your increase or decrease the volume control from the keyboard, OSX will bring up a transparent scale of the volume setting, does Vista have the same feature??... I tried looking through most of the setting and can not find anything . thanks all... |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Transparent Volume scale Hey everyone... I have Vista Home Prem with a MS 2000 keyboard that has the volume control feature on the kb.... Does Vista have a feature like Mac OSX where if your increase or decrease the volume control from the keyboard, OSX will bring up a transparent scale of the volume setting, does Vista have the same feature??... I tried looking through most of the setting and can not find anything . thanks all... I believe it has to do with the keyboard drivers or software on whether or not it also pops up the Volume slider from the Volume icon in the Notification area of the taskbar. If I want to see the Volume slider when I use the keyboard volume buttons, I have to click on the Volume icon first. Otherwise the keyboard volume buttons will adjust the volume with only the reference of the number of waves coming out of the right side of the Volume icon. To see how to have the Volume icon showing in the notification area of the taskbar, see: Notification Area - System Icons Hope this helps, Shawn |
| | Re: Transparent Volume scale The MS Keyboard has a 'Properties' key, between the right windows key, and the right ctrl key. If you press the volume key, then the Properties key, you should get a slider on the volume icon in the Notifications area. Escape out. There is a checkbox for showing the Volume icon on Control Panel/ Sounds/Audio tab. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "Cory Mariani" <cb900f2cnd@xxxxxx> wrote in message news:8C365D40-D667-4D72-80C1-89D33C8CF47C@xxxxxx Quote: > Hey everyone... I have Vista Home Prem with a MS 2000 keyboard that has > the volume control feature on the kb.... Does Vista have a feature like > Mac OSX where if your increase or decrease the volume control from the > keyboard, OSX will bring up a transparent scale of the volume setting, > does Vista have the same feature??... I tried looking through most of the > setting and can not find anything . > > thanks all... > > |
| | Re: Transparent Volume scale There is a volume level display that does pop up within Media Center, but there isn't one available on the basic Windows desktop. If it exists at all any on-screen display of the volume level would be provided by a custom keyboard driver. For example, HP includes on-screen volume level display with its multimedia keyboard drivers. If the MS keyboard came with a driver disc try installing that and look for settings pertaining to on screen display. "Cory Mariani" <cb900f2cnd@xxxxxx> wrote in message news:8C365D40-D667-4D72-80C1-89D33C8CF47C@xxxxxx Quote: > Hey everyone... I have Vista Home Prem with a MS 2000 keyboard that has > the volume control feature on the kb.... Does Vista have a feature like > Mac OSX where if your increase or decrease the volume control from the > keyboard, OSX will bring up a transparent scale of the volume setting, > does Vista have the same feature??... I tried looking through most of the > setting and can not find anything . > > thanks all... > > |
| Help! Is this true? Embedded pics won't scale down to fit screen? | Vista mail | |||
| printing in grey scale | Vista print fax & scan | |||
| Blurry fonts when changing DPI scale with LCD screen | Vista hardware & devices | |||
| Keeping wallpapers to scale | Vista music pictures video | |||
