Vista - print problems with works 8.0
Old 04-13-2008   #1 (permalink)
Gino-C
I have an HP SR2170NX and an HP 7350 printer. Per HP, I had to install it as
a 5550 and it almost works great. It will print a calendar, 1 of 2
spreadsheets, any word processor document except envelopes & amusingly the
grid lines & dollar amounts of my tax returns from Turbo Tax, but not the
descriptions of those lines. It goes through the motions, feeding paper,
print head flying but nothing is printed.Printer test is perfect, ink is OK,
printer has been un & re installed, Adobe & internet print OK. No jams, no
shut-downs. Any suggestions short of an exorcist?
dogged victim of inexorable technology
can I print a selection in Works? Vista print fax & scan
Works crashes when trying to print Vista print fax & scan
Works won't print in Vista Vista print fax & scan
RE: Cannot print from Works 8 spreadsheet Vista print fax & scan
Can't print from IE anymore. OE print still works Vista print fax & scan
