| | no color settings for nVidia control panel When I bring up the nVidia control panel, it doesn't have any of the color controls like brightness and contrast. The help file says I should select "Display" from the initial "Select a Category" page, but the only thing I get for "Display" is "Multiple Displays". Except for that, it's an empty page. And I only have one display, so that doesn't do anything either. This is a Presario SR2002X, originally with XP. The Vista upgrade DVD had an option to either upgrade XP or install Vista clean. I did a clean install. I also went to hp.com and downloaded the latest nVidia GeForce driver, version 7.15.10.9734, and installed it. So, what's happened to the color controls? Is there some way to get them working? Thanks, Wee Willie |
| | RE: no color settings for nVidia control panel You should get the drivers right from the nVidia site. From the sounds of it the Control Panel is not fully functional. Have you tried under the Advanced settings? "smithwilford@xxxxxx" wrote: Quote: > When I bring up the nVidia control panel, it doesn't have any of the > color controls like brightness and contrast. The help file says I > should select "Display" from the initial "Select a Category" page, but > the only thing I get for "Display" is "Multiple Displays". Except for > that, it's an empty page. And I only have one display, so that > doesn't do anything either. > > This is a Presario SR2002X, originally with XP. The Vista upgrade DVD > had an option to either upgrade XP or install Vista clean. I did a > clean install. I also went to hp.com and downloaded the latest nVidia > GeForce driver, version 7.15.10.9734, and installed it. > > So, what's happened to the color controls? Is there some way to get > them working? > > Thanks, > Wee Willie > |
| | Re: no color settings for nVidia control panel smithwilford@xxxxxx wrote: Quote: > When I bring up the nVidia control panel, it doesn't have any of the > color controls like brightness and contrast. The help file says I > should select "Display" from the initial "Select a Category" page, but > the only thing I get for "Display" is "Multiple Displays". Except for > that, it's an empty page. And I only have one display, so that > doesn't do anything either. > > This is a Presario SR2002X, originally with XP. The Vista upgrade DVD > had an option to either upgrade XP or install Vista clean. I did a > clean install. I also went to hp.com and downloaded the latest nVidia > GeForce driver, version 7.15.10.9734, and installed it. > > So, what's happened to the color controls? Is there some way to get > them working? > > Thanks, > Wee Willie FWIW...the driver you mentioned was released in November 2006. See the following article: NVIDIA_video_97.34_logo_Desktop.zip - 7.15.10.9734 http://www.versiontracker.com/dyn/moreinfo/win/136527 According to the following article your system includes the NVIDIA GeForce 6150 LE graphics adapter. Hewlett Packard Compaq Presario SR2002X PC Desktop http://www.epinions.com/Hewlett_Pack...ay_~full_specs Might be worth a try to download a more current driver for your Video Adapter from the nVidia site: http://www.nvidia.com/Download/index.aspx?lang=en-us Looks like this one may be a good choice: http://www.nvidia.com/object/winvist...9.25_whql.html Also...have a look at the Driver Installation Hints: http://www.nvidia.com/object/driver_...ion_hints.html Good luck..... -- John Inzer Digital Media MVP Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| | Re: no color settings for nVidia control panel On Apr 14, 9:18*am, "John Inzer" <oo...@xxxxxx> wrote: Quote: > Also...have a look at the Driver Installation Hints:http://www.nvidia.com/object/driver_...ion_hints.html Do not run virus protection software in the background while installing the drivers. This prevents the driver from configuring itself properly. |
| | Re: no color settings for nVidia control panel smithwilford@xxxxxx wrote: Quote: > On Apr 14, 9:18 am, "John Inzer" <oo...@xxxxxx> wrote: Quote: >> Also...have a look at the Driver Installation >> Hints:http://www.nvidia.com/object/driver_...ion_hints.html > Thanks. This is probably the problem: > Do not run virus protection software in the background while > installing the drivers. This prevents the driver from configuring > itself properly. Running an outdated driver is not helping either. -- John Inzer Digital Media MVP Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| | #6 (permalink) |
| | Re: no color settings for nVidia control panel On Apr 14, 10:22*am, "John Inzer" <oo...@xxxxxx> wrote: Quote: > Running an outdated driver is not helping either. virus software disabled first because I have a slow dial-up connection with limited connect sessions. But the old driver still didn't work, so I had to try the newer version. Once I got it downloaded and installed, it solved the problem. The nVidia control panel has full functionality now. ![]() Thanks again. |
| Nvidia Control Panel crashes - 3D settings problem | Graphic cards | |||
| Control Panel/ Color Scheme doesn't work:( | Vista performance & maintenance | |||
| Color Management Applet in Control Panel | Vista music pictures video | |||
| NVidia Control Panel in 88.61 | Vista hardware & devices | |||
| Nvidia Control Panel? | Vista hardware & devices | |||
