Pinnacle PCTV Rave Tuner not detected by MediaCenter
  1. #1
    Schevenels Patrick Guest
    Hello.
    The TV tuner of my card Pinnacle PCTV Rave is not detected by Windows Vista
    Media Center (both on Beta 2 and on Pre-RC1, both with Windows Update
    drivers and with drivers provided with the card).
    How could I have this tuner detected by Media Center ?
    Thanks
    Patrick Schevenels
  2. #2
    JW Guest
    Re: Pinnacle PCTV Rave Tuner not detected by MediaCenter
    I doublt that you received Vista drivers for you card with the card they are
    most likely Windows XP drivers.
    Are you saying that when you ran WinUpdate while running Vista that found
    new drivers for you and you installed them?
    Have you checked the Pinnacle WebSite for Vista drivers for your card since
    they may have some that have not yet been qualified by MS?
    "Schevenels Patrick" <pscheven@hotmail.com> wrote in message
    news:CAB61770-C5F8-4517-B16F-6BBD69F55018@microsoft.com...
    > Hello.
    > Vista Media Center (both on Beta 2 and on Pre-RC1, both with Windows
    > Update drivers and with drivers provided with the card).
    > Thanks
    > Patrick Schevenels
  3. #3
    Yes, the drivers given with the card are for Windows XP.
    On Windows Vista, it installs drivers from Windows Update by default but the
    tuner is not detected.
    On Pinnacle website, there's no driver for Windows Vista.
    "JW" <nospam@no.spam> wrote in message
    news:eYBIj1PzGHA.3704@TK2MSFTNGP02.phx.gbl...
    >are most likely Windows XP drivers.
    > since they may have some that have not yet been qualified by MS?
  4. #4
    JW Guest
    In order for a tuner card to be supported by Media Center it must support
    DX9 rendering and it must have a hardware encoder chip on board with MCE
    (BDA) drivers.
    Assording to the following link your card does not have theses features and
    Pinnalce makes no claim that it works with MCE.
    http://www.pinnaclesys.com/PublicSit...Specifications
    A
    news:8EDE7AF7-9CFE-455D-9E03-22CC50B637A8@microsoft.com...
    > the tuner is not detected.
Pinnacle PCTV Rave Tuner not detected by MediaCenter problems?
Pinnacle PCTV Rave software matijanspace Media Center 5 25 May 2008
Where to find Pinnacle PCTV RAVE Drivers for Vista x64? amitkarir Drivers 5 13 May 2008
pinnacle pctv rave Pascal Free Vista hardware & devices 0 24 Oct 2006
Pinnacle PCTV Rave Tuner not detected by MediaCenter Schevenels Patrick Vista hardware & devices 3 31 Aug 2006
Pinnacle PCTV Rave Tuner not detected by MediaCenter Schevenels Patrick Vista music pictures video 3 31 Aug 2006
