| | Tilde Key will not work on games in Vista 32bit Hi, i have a new HP pc desktop and the Tilde Key will not work i have tried everything i know different keyboard i do know its windows Vista because i have played these games on XP with no problems,so whats happening Microsoft. ![]() -- Reptaker Posted via http://www.vistaheads.com |
| | Re: Tilde Key will not work on games in Vista 32bit Have you been into regional settings to change the key board or just used a different bit of hardware "Reptaker" <Reptaker.37yfgh@xxxxxx-mx.forums.vistaheads.com> wrote in message news:Reptaker.37yfgh@xxxxxx-mx.forums.vistaheads.com... Quote: > > Hi, i have a new HP pc desktop and the Tilde Key will not work i have > tried everything i know different keyboard i do know its windows Vista > because i have played these games on XP with no problems,so whats > happening Microsoft. ![]() > > > -- > Reptaker > Posted via http://www.vistaheads.com > |
| | Re: Tilde Key will not work on games in Vista 32bit Reptaker;789088 Wrote: Quote: > Hi, i have a new HP pc desktop and the Tilde Key will not work i have > tried everything i know different keyboard i do know its windows Vista > because i have played these games on XP with no problems,so whats > happening Microsoft. ![]() H.P.9180uk-a desktop,i have tried the brand new keyboard that came with the pc and the Tilde Key doe's not work with that Keyboard, also i have a brand new Logitech G15 Gaming Keyboard and the Tilde Key still won't function to bring down the console,the tilde key works O.K. on notepad also works O.K. in microsoft works, its the console in my games it doe's not recognize the Tilde Key,the games are for to many to mention all heres a couple Oblivion,Two Worlds both RPG's and on windows XP i have no trouble with the Tilde Key,i have used this Logitech G15 on both games in windows XP all was well,but in Vista the Tilde key will not work and thats why i think its a microsoft problem! -- Reptaker Posted via http://www.vistaheads.com |
| | Tidle Key I've had this issue when using Windows XP Media Center 2005. I've since upgraded to Windows Vista Home Premium, which is on a completely different system. The only things in common are media center and the MCE remote. While reading through other gaming threads, some suggest unplugging the remote (if applicable) and the '~' key then works. I do think Microsoft should address this issue, since it is their hardware/software conflicting with games; Crysis, Oblivion, etc. Unpluging or disabling a USB is not a solution. |
| | Re: Tilde Key will not work on games in Vista 32bit Thanx Dan, I also think that Microsoft should carry the blame after all they have the money and the brains, another thing is my library of games is just about DEAD and that library cost me a small fortune just because i moved over to Vista via, a new pc in April, i also think i should be compensated via microsoft because of my loss.see ya Reptaker. ![]() -- Reptaker Posted via http://www.vistaheads.com |
| Will my 64bit activation key work for 32bit Vista? | General Discussion | |||
| Games for 32bit vista? | Gaming | |||
| Tilde Key not responsiv in a few games, something to do with IR. | Vista General | |||
| will Windows marketplace 32bit vista key work with the same 64bit | Vista General | |||
| will Windows marketplace 32bit vista key work with the same 64bit | Vista installation & setup | |||
