| | wireless not work after install SP1 Hi, My thinkpad laptop runs Windows Vista. the wireless worked ok before I install Vista SP1. After installing SP1, I only can actually view my wireless connections, I see everything, but upon connecting I get the "Connection is taking longer than usual" crap. I reinstalled the drivers, but no go. When Vista does the diagnostics, it says "The network adapter 'wireless network connection' is not correctly configured to use the IP protocol'". Then, there are two options below. 1 is about hardware and driver issues, the other is about the internet protocol bindings and IPv4 and Ipv6 being installed (which they are). Anyone have an idea how I can fix this? Does anyone experience the same thing after installing SP1 Thanks |
| | Re: wireless not work after install SP1 Sometimes, after an SP1 update, drivers need to be removed and scanned for again in Device manager. A device driver is not installed, or a hardware device does not function correctly after you install Windows Vista Service Pack 1: http://support.microsoft.com/?kbid=948187 -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "qnguyen" <qnguyen@xxxxxx> wrote in message news 9D2E7E1-6188-46E7-9C19-25EB8D243F44@xxxxxxQuote: > Hi, > My thinkpad laptop runs Windows Vista. the wireless worked ok before I > install Vista SP1. > After installing SP1, I only can actually view my wireless connections, I > see everything, but upon connecting I get the "Connection is taking longer > than usual" crap. I reinstalled the drivers, but no go. > > When Vista does the diagnostics, it says "The network adapter 'wireless > network connection' is not correctly configured to use the IP protocol'". > Then, there are two options below. 1 is about hardware and driver issues, > the other is about the internet protocol bindings and IPv4 and Ipv6 being > installed (which they are). > > Anyone have an idea how I can fix this? > Does anyone experience the same thing after installing SP1 > Thanks |
| | Re: wireless not work after install SP1 "qnguyen" <qnguyen@xxxxxx> wrote in message news 9D2E7E1-6188-46E7-9C19-25EB8D243F44@xxxxxxQuote: > Hi, > My thinkpad laptop runs Windows Vista. the wireless worked ok before I > install Vista SP1. > After installing SP1, I only can actually view my wireless connections, I > see everything, but upon connecting I get the "Connection is taking longer > than usual" crap. I reinstalled the drivers, but no go. > > When Vista does the diagnostics, it says "The network adapter 'wireless > network connection' is not correctly configured to use the IP protocol'". > Then, there are two options below. 1 is about hardware and driver issues, > the other is about the internet protocol bindings and IPv4 and Ipv6 being > installed (which they are). > > Anyone have an idea how I can fix this? > Does anyone experience the same thing after installing SP1 Have you tried using ThinkVantage System Update since you installed SP1? ss. |
| | Re: wireless not work after install SP1 Thank for your help. I did try reinstall and update all drivers but still helpless. "Synapse Syndrome" <synapse@xxxxxx> wrote in message news:ubQIC2%23nIHA.1036@xxxxxx Quote: > "qnguyen" <qnguyen@xxxxxx> wrote in message > news 9D2E7E1-6188-46E7-9C19-25EB8D243F44@xxxxxxQuote: >> Hi, >> My thinkpad laptop runs Windows Vista. the wireless worked ok before I >> install Vista SP1. >> After installing SP1, I only can actually view my wireless connections, I >> see everything, but upon connecting I get the "Connection is taking >> longer than usual" crap. I reinstalled the drivers, but no go. >> >> When Vista does the diagnostics, it says "The network adapter 'wireless >> network connection' is not correctly configured to use the IP protocol'". >> Then, there are two options below. 1 is about hardware and driver issues, >> the other is about the internet protocol bindings and IPv4 and Ipv6 being >> installed (which they are). >> >> Anyone have an idea how I can fix this? >> Does anyone experience the same thing after installing SP1 > > Have you tried using ThinkVantage System Update since you installed SP1? > > ss. > |
| | Re: wireless not work after install SP1 Hi, I am also having the same problem. My broadcom wireless hardware itself is not detected. Unfortunately, I had to uninstall the SP1 updates and it starts working. For the time being I am avoiding SP1. I am not sure of the issue, please suggest, so that I can get Sp1. Thanks, Rahul |
| Wireless/LAN dont work | Network & Sharing | |||
| wireless will not work with any adapter | Network & Sharing | |||
| my wireless RF keyboard does' nt work | Vista hardware & devices | |||
| Wireless used to work but doesn't now | Vista networking & sharing | |||
| HELP! Wireless doesn't work, LAN does? | Vista networking & sharing | |||
