| | Video resolution settings problem While using Vista I checked my video settings - it knew my monitor and nvidia card and was surprised to see that 1024x768 was so far to the left on my scale - so I tried a higher resolution. My Viewsonic then displayed OUT OF RANGE in red letters on a black screen and that's it - yellow power LED. I thought after ~10 seconds of my not "accepting it" , it would go back as XP used to: apparently not. I waited but no change-.that's something that needs to be fixed. I did a "windows key" and 2 right arrows and a CR (to have it shutdown)and it restarted . |
| | RE: Video resolution settings problem This ABSOLUTELY should be fixed. It's not just been this way since XP, it's been this way since Windows95 AT LEAST. Maybe earlier? I dunno. It makes choosing the highest display resolution possible a huge pain in the rump. I'm forced to RESTART into SAFE MODE, then roll back settings, then try again. This can't be the best solution. Any plans to correct this? Q "- Bobb -" wrote: > While using Vista I checked my video settings - it knew my monitor and > nvidia card and was surprised to see that 1024x768 was so far to the > left on my scale - so I tried a higher resolution. My Viewsonic then > displayed OUT OF RANGE in red letters on a black screen and that's it - > yellow power LED. I thought after ~10 seconds of my not "accepting it" > , it would go back as XP used to: apparently not. I waited but no > change-.that's something that needs to be fixed. I did a "windows key" > and 2 right arrows and a CR (to have it shutdown)and it restarted . > > |
| Monitor Resolution and Bit Settings Keep changing | Vista hardware & devices | |||
| Changing Display Settings (Resolution mainly) through Safe Mode | Vista General | |||
| HD Video Resolution | Vista General | |||
| LCD Monitor loses resolution settings | Vista hardware & devices | |||
| Resolution and display settings | Vista performance & maintenance | |||
