Vista - Analog tuner stops working after vista sp1 installation
Old 04-17-2008   #1 (permalink)
Roberto
My MSI TV Anywhere A/D 1.1 analog tuner stops working after vista SP1
installation. Digital tuner works fine.
I've latest drivers and bios, I've also format my HD and started a clean
installation, same problem. No problem without vista SP1.
Any suggestion?
My computer: Intel D945 (3.4 GHz x2), Asus P5KPL, 2 GB DDR2 kingstone,
GeForce 8600GT 512MB, TV Anywhere A/D 1.1, Vista Home Premium 32bit OEM
Thenks and best regards.
Old 04-17-2008   #2 (permalink)
Mark L. Ferguson
Re: Analog tuner stops working after vista sp1 installation
A device driver is not installed, or a hardware device does not function
correctly after you install Windows Vista Service Pack 1:
http://support.microsoft.com/?kbid=948187
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Roberto" <Roberto@xxxxxx> wrote in message
news:E324E726-62BB-4851-97BE-D2DA0C1D0DD6@xxxxxx
> Any suggestion?
Old 04-17-2008   #3 (permalink)
Roberto
Thanks but I've already tryed this tip. The driver is found, no exclamation
point, I've Uninstalled and then reinstalled the device drivers. The problem
remains.
Thanks.
> interface.
> Mark L. Ferguson
> > Any suggestion?
Old 04-17-2008   #4 (permalink)
Dwarf
RE: Analog tuner stops working after vista sp1 installation
Hi Roberto,
This is reminiscent of the situation that ocurred when SP2 was released for
XP. Some devices and programs stopped working, and these typically required
updates from the manufacturer that were compliant with the newer version of
the OS. You need to keep checking the manufacturer's website for any patches
that may be available for your device. Please note that there is inevitably a
delay between the release of a service pack and that of a patch to enable a
device or program to work with that service pack. In some cases, no patches
will be upcoming and the only solution is to obtain a new device or program
that is compliant.
Dwarf
> Any suggestion?
Old 04-18-2008   #5 (permalink)
Roberto
I agree.
There is no driver update planned at this moment on MSI, TV Anywhere A/D 1.1
has a logo "Certified For Windows Vista"... Vista service Pack beta realases,
realase candidates are distributed for testing (and solve) any problem:
MSI????
MSI is not serious if not issuing a driver "SP1 capable" very soon...
Thanks!
Roberto.
"Dwarf" wrote:
Quote:
> Hi Roberto,
> that is compliant.
> Dwarf
> > Any suggestion?
Problems with Media Center and analog TV Tuner Media Center
Analog Tuner won't work with 2 Digital Tuners installed? Vista General
Processor upgrade stops tuner working Vista hardware & devices
RE: toshiba hybrid digital (DVB-T) and analog TV tuner Vista music pictures video
VISTA INSTALLATION STOPS NEAR THE END Vista installation & setup
