Vista - External HDD does not work
Old 04-18-2008   #1 (permalink)
Vista Ultimate 32bit
I have a samsung external HDD after using it for a while I get the message " volume// is not accessible " on all local drives. What cause this problem??
I try many programs to solve this problem and it does not work. The only solution is to format all local drives.
Old 04-18-2008   #2 (permalink)
Mark L. Ferguson
Re: External HDD does not work
The "Power Management" tab on the device Properties of the port used to
connect the volume is being allowed to 'turn off the power to this device"
Something like:
devmgmt.msc
USB Root Hub device properties (or whatever device)
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"ahmad12" <ahmad12.382iq5@xxxxxx-mx.forums.net> wrote in message
news:ahmad12.382iq5@xxxxxx-mx.forums.net...
> this problem??
> ahmad12
Old 04-18-2008   #3 (permalink)
I have a 80 GB samsung external HDD with two partitions C: & D: after using this HDD many times I have the following message: C:\ is not accessible The file or directory is corrupted and unreadable
D:\ is not accessible The file or directory is corrupted and unreadable
chkdsk does not work and the file system is RAW the HDD works again only when I format it.
Any thoughts on what's going on here and how to fix it?
speakers randomly wont work sometimes on laptop but external will sometime work Sound & Audio
Can't get external monitor to work Vista hardware & devices
Getting an external projector to work Vista General
External manifest file does not work Vista General
External USB Drives will not work on VISTA Vista General
