Vista - Installation problems
Old 04-19-2008   #1 (permalink)
HotRod Harry
I have reinstalled Vista Ultimate 32 bit 2 times today because I thought I
had a virus. I can't get a stable install. I get Vista installed and then
start to install my programs when it hangs. Here's what I did....
After installation I installed Avast AV. Restarted, got connected and went
to install my soundcard. As soon I clicked install I went into a loop or
something. Nothing but the hourglass or whatever in Vista. I manually
shutdown and decided to try the built-in soundcard. The other was a USB. As
soon as I clicked anything I go to never, neverland. I can't get out of it
unless I manually restart. This is the reason I reformatted to begin with.
After restarting I go in to this loop or whatever whenever click anything.
Anyone have any idea what might be happening? Thanks.
Old 04-19-2008   #2 (permalink)
HotRod Harry
Re: Installation problems
Addendum: This was a clean install both times. Completely reformatted the
drive both times and used bootrec to clean my master boot record. Did that
twice, hope it worked. I've been using Vista Ultimate 32 bit and 64 bit for
1 1/2 years and I'm thinking of going back to XP. I've never had a problem
like this before with Vista.
"HotRod Harry" <hh@xxxxxx> wrote in message
news:%23ULlhPnoIHA.3976@xxxxxx
> As soon as I clicked anything I go to never, neverland. I can't get out of
> it unless I manually restart. This is the reason I reformatted to begin
> with. After restarting I go in to this loop or whatever whenever click
> anything. Anyone have any idea what might be happening? Thanks.
Old 04-20-2008   #3 (permalink)
Gary Mount
The first thing to do after a fresh install is to update your drivers, such
as your video driver.
news:#ULlhPnoIHA.3976@xxxxxx
Old 04-20-2008   #4 (permalink)
HotRod Harry
Thanks for the reply, Gary. I thought it was my 2 soundcards causing the
problem so I turned off the onboard soundcard in the bios. I then installed
the other soundcard and it installed fine. Restarted and it hangs as soon as
I start doing anything. It's hard to update drivers when the system won't
stay stable enough to let you.
"Gary Mount" <gary_mount@xxxxxx> wrote in message
news:%230fyyxpoIHA.4308@xxxxxx
> such as your video driver.
>> I had a virus. I can't get a stable install. I get Vista installed and
>> then start to install my programs when it hangs. Here's what I did....
>> went to install my soundcard. As soon I clicked install I went into a
>> loop or something. Nothing but the hourglass or whatever in Vista. I
>> manually shutdown and decided to try the built-in soundcard. The other
>> was a USB. As soon as I clicked anything I go to never, neverland. I
>> can't get out of it unless I manually restart. This is the reason I
>> reformatted to begin with. After restarting I go in to this loop or
>> whatever whenever click anything. Anyone have any idea what might be
>> happening? Thanks.
Old 04-21-2008   #5 (permalink)
Hotrod Harry
It seems to be stable again. All seems well but I look for it to go nuts at
any given moment. That's the way it was on the previous install.
Installation Problems Vista print fax & scan
Installation Problems Vista installation & setup
Installation problems Vista General
