| | Vista Ultimate Big Problems I currently use Vista Business and had the opportunity to purchase Vista Ultimate +Sp1 Backed everything up, went for a clean install (even formatted the disk)... Ultimate however, right from the start was a disaster - Loads of appcrash errors Every time I closed internet explorer, it caused a fault and restarted (explorer has stopped working) Virus software couldn't update Even a blue screen! Every boot, I was getting a screen message telling me vista was checking the disk and finding it 'clean' Start menu was like in slow motion and many more errors Think to myself, hmmm, maybe a duff installation and driver issues. So, wipes disk, does another brand new clean installation and this time didnt even bother doing anything with drivers, virus software and anything else... guess what Same problems - Vista Ultimate just doesn't want to work on my machine. I've since re-installed business and its flawless. How/Why can this happen? Is it a bad burn maybe (vista +SP1 downloaded from microsoft)?? Any other suggestions, or is ultimate so different from business that this is not entirely unexpected? cheers, g. |
| | Re: Vista Ultimate Big Problems Hi Gordon, Was your Business version preinstalled? If so, it likely was modified to contain drivers specific to your machinery that are not in the retail version. A better path for you would be to reinstall it, then upgrade in place to Ultimate so that they are carried over. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Gordon Martin" <port_26@xxxxxx> wrote in message news:uO7gwUuoIHA.4716@xxxxxx Quote: >I currently use Vista Business and had the opportunity to purchase Vista >Ultimate +Sp1 > > Backed everything up, went for a clean install (even formatted the > disk)... > Ultimate however, right from the start was a disaster - > Loads of appcrash errors > Every time I closed internet explorer, it caused a fault and restarted > (explorer has stopped working) > Virus software couldn't update > Even a blue screen! > Every boot, I was getting a screen message telling me vista was checking > the disk and finding it 'clean' > Start menu was like in slow motion > and many more errors > > Think to myself, hmmm, maybe a duff installation and driver issues. > > So, wipes disk, does another brand new clean installation and this time > didnt even bother doing anything with drivers, virus software and anything > else... guess what > Same problems - Vista Ultimate just doesn't want to work on my machine. > > I've since re-installed business and its flawless. > > How/Why can this happen? > > Is it a bad burn maybe (vista +SP1 downloaded from microsoft)?? > > Any other suggestions, or is ultimate so different from business that this > is not entirely unexpected? > > cheers, > g. |
| | Re: Vista Ultimate Big Problems Cheers Rick, to answer, no... My machine was preinstalled with XP. I did the vista business upgrade a while back. I might try an 'ultimate' upgrade rather than clean install - but my nerves wont take it right now - maybe give it a month or two. g. "Rick Rogers" <rick@xxxxxx> wrote in message news:OyHbHYuoIHA.1736@xxxxxx Quote: > Hi Gordon, > > Was your Business version preinstalled? If so, it likely was modified to > contain drivers specific to your machinery that are not in the retail > version. A better path for you would be to reinstall it, then upgrade in > place to Ultimate so that they are carried over. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Gordon Martin" <port_26@xxxxxx> wrote in message > news:uO7gwUuoIHA.4716@xxxxxx Quote: >>I currently use Vista Business and had the opportunity to purchase Vista >>Ultimate +Sp1 >> >> Backed everything up, went for a clean install (even formatted the >> disk)... >> Ultimate however, right from the start was a disaster - >> Loads of appcrash errors >> Every time I closed internet explorer, it caused a fault and restarted >> (explorer has stopped working) >> Virus software couldn't update >> Even a blue screen! >> Every boot, I was getting a screen message telling me vista was checking >> the disk and finding it 'clean' >> Start menu was like in slow motion >> and many more errors >> >> Think to myself, hmmm, maybe a duff installation and driver issues. >> >> So, wipes disk, does another brand new clean installation and this time >> didnt even bother doing anything with drivers, virus software and >> anything else... guess what >> Same problems - Vista Ultimate just doesn't want to work on my machine. >> >> I've since re-installed business and its flawless. >> >> How/Why can this happen? >> >> Is it a bad burn maybe (vista +SP1 downloaded from microsoft)?? >> >> Any other suggestions, or is ultimate so different from business that >> this is not entirely unexpected? >> >> cheers, >> g. |
| | Re: Vista Ultimate Big Problems "Gordon Martin" <port_26@xxxxxx> wrote in message news:uO7gwUuoIHA.4716@xxxxxx Quote: >I currently use Vista Business and had the opportunity to purchase Vista >Ultimate +Sp1 > > Backed everything up, went for a clean install (even formatted the > disk)... > Ultimate however, right from the start was a disaster - > Loads of appcrash errors > Every time I closed internet explorer, it caused a fault and restarted > (explorer has stopped working) > Virus software couldn't update > Even a blue screen! > Every boot, I was getting a screen message telling me vista was checking > the disk and finding it 'clean' > Start menu was like in slow motion > and many more errors > > Think to myself, hmmm, maybe a duff installation and driver issues. > > So, wipes disk, does another brand new clean installation and this time > didnt even bother doing anything with drivers, virus software and anything > else... guess what > Same problems - Vista Ultimate just doesn't want to work on my machine. > > I've since re-installed business and its flawless. > > How/Why can this happen? > > Is it a bad burn maybe (vista +SP1 downloaded from microsoft)?? > > Any other suggestions, or is ultimate so different from business that this > is not entirely unexpected? > > cheers, > g. Gordon, When you reinstalled Business... did you do so as a clean install or did you reinstall XP and upgrade again? Lang |
| Vista Ultimate 32bit | Re: Vista Ultimate Big Problems Gordon, Always make a fresh installation of Windows Vista that is recommended. Then install an updated antivirus to ensure you haven't viruses on your PC. |
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| problems with vista ultimate | Vista General | |||
| Vista Ultimate 64 MC problems | Vista music pictures video | |||
| Vista Ultimate problems | Vista installation & setup | |||
| VISTA Ultimate Problems | Vista General | |||
