Vista - Hard drive cable question
Old 04-20-2008   #1 (permalink)
Ed\(NY\)
I'm trying to install an additional (SATA) hard drive - it appears I need a
cable that can connect to the 8 pin power connection on the hard drive and
then to the EIDE 15 pin connector on the cable coming from the hard drive in
the computer. I can't find a cable that can do this. Do I need to combine
two cables (15 to 4 pin, then 4 to 8?)
Old 04-20-2008   #2 (permalink)
DL
Re: Hard drive cable question
Do you not have several sata connectors on your motherboard?
The sata cable is about 1/2" wide an Ide cable about 2"
Do you not have a spare power connector on your power cables to plug into
the drive?
(look at the wiring on your current sata drive)
You certainly dont connect the ide cable to a sata power connection
"Ed(NY)" <ebny@xxxxxx> wrote in message
newsVKOj.128$NK1.96@xxxxxx
> a cable that can connect to the 8 pin power connection on the hard drive
> and then to the EIDE 15 pin connector on the cable coming from the hard
> drive in the computer. I can't find a cable that can do this. Do I need
> to combine two cables (15 to 4 pin, then 4 to 8?)
Old 04-20-2008   #3 (permalink)
John Barnett MVP
SATA cables don't plug into the EIDE socket, the connector on both ends of
the cable are exactly the same and need to be plugged into the SATA drive
and a dedicated SATA connector on your motherboard - there are usually 4
SATA connectors on the motherboard each around half and inch in width.
John Barnett MVP
Associate Expert
Windows Desktop Experience
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
Old 04-20-2008   #4 (permalink)
Ed\(NY\)
"John Barnett MVP" <freelance@xxxxxx> wrote in message
news:OuSiuZyoIHA.4760@xxxxxx
>Sorry - I was incorrect. It's not an EIDE connection, but SATA. My
>existing hard drives are SATA as is the new one. It's a matter of finding
>the right cable.
Thanks.
Old 04-20-2008   #5 (permalink)
the wharf rat
Ummmmm it sounds like your machine doesn't have a SATA port.
If the cables dont have any place to go then you need an adaptor card.
Old 04-20-2008   #6 (permalink)
DL
You would have to buy a sata cable
You would usually excpect to find a spare sata power connection allready
present on your power cables in the PC
news:aAOOj.405$wO1.96@xxxxxx
>> of the cable are exactly the same and need to be plugged into the SATA
>> drive and a dedicated SATA connector on your motherboard - there are
>> usually 4 SATA connectors on the motherboard each around half and inch in
>> width.
>>the right cable.
> Thanks.
Old 04-21-2008   #7 (permalink)
John Barnett MVP
You should be able to get a cable from any good computer store.
John Barnett MVP
Associate Expert
mail/post..
>> width.
>>the right cable.
> Thanks.
Old 04-21-2008   #8 (permalink)
Michael Heath
You can find various SATA cables and connectors here
http://www.findacable.com/servlet/th...ies/Categories
However, you can't connect a SATA drive to an IDE controller. You must have a SATA controller.
Hard drive question Vista hardware & devices
Hard Drive Question Vista hardware & devices
hard drive question Vista General
New hard drive question Vista General
