"No Audio Output Device is installed"
  1. #1
    Paul H Guest
    I did another restart of my Vista to remove constipation, etc. This time I
    have no sound. it says "No Audio Output Device is installed". How do I get
    sound back on my Acer 5610 laptop?
  2. #2
    Malke Guest
    Re: "No Audio Output Device is installed"
    > I
    > get sound back on my Acer 5610 laptop?
    Install the drivers. Get them from Acer's website for your specific model
    laptop. Install all drivers, including the chipset, as well as any
    laptop-specific software such as for power management.
    Malke
    MS-MVP
    Elephant Boy Computers
    www.elephantboycomputers.com
    Don't Panic!
  3. #3
    Paul H Guest
    Thanks. I'll try that. It's very frustrating to have to deal with things
    like this - my XP Pro on my old laptop stays like I leave it. But my Vista
    Home Premium frequently does me little favors like this. Real time wasters.
    "Malke" <malke@xxxxxx> wrote in message
    news:ecDrecxoIHA.1420@xxxxxx
    I have no sound. it says "No Audio Output Device is installed". How do I
    Malke
    MS-MVP
    Don't Panic!
  4. #4
    Christoph Guest
    After doing a RegCure, Reg Defrag and some MS Updates on my new HP
    Laptop I got this same problem. Whatever I tried did not work,
    including going to HP for the audio driver, soooo I just went to the
    Windows driver error selection and let Windows fix the problem on-line.
    It solved everything instantly. Interestingly enough when I was trying
    to fix the problem I noticed in Hardware Devices that the audio drive
    was not to be found and in other inspections it was alive and working
    properly.
    Christoph
    Posted via http://www.vistaheads.com
  5. #5
    Bob Guest
    DO NOT use registry cleaners! See this:
    http://aumha.net/viewtopic.php?t=28099
    "Christoph" <Christoph.386nc3@xxxxxx-mx.forums.vistaheads.com> wrote in message
    news:Christoph.386nc3@xxxxxx-mx.forums.vistaheads.com...
    > properly.
    > Christoph
"No Audio Output Device is installed" problems?
"No Audio Output Device Installed" Vistaz Sound & Audio 13 14 Sep 2012
Help Needed: "No audio output device is installed" SamanthaAmy Sound & Audio 2 25 Jan 2009
Dell and "no audio output device installed" after Vista upgrade silksoul4u Vista hardware & devices 6 13 Aug 2008
"No Audio Output Device is installed" DT Vista hardware & devices 0 25 Jul 2008
"No audio output device is installed" upon wake-up... Justin Vista hardware & devices 6 19 Jul 2007
