| | Vista installation of various programs issue.. shortcuts not creat I'm running vista x64 with 4GB memory.. for some reason.. on any new apps i install.. it seems the shortcuts dont get created.. often it will create the folder for them, but no icons.. Has anyone run into this and know of a fix? Thanks |
| | Re: Vista installation of various programs issue.. shortcuts not creat Right click, an Command Prompt shortcut, 'run as administrator' End task on 'Explorer' in Task Manager At the prompt, go to C:\Users\<user>\AppData\Local atrib -h IconCache.db del IconCache.db start explorer (or restart Windows) -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "markm75" <markm75@xxxxxx> wrote in message news:6FA0E11C-8DA8-4C21-A0FB-845AD77CEE60@xxxxxx Quote: > I'm running vista x64 with 4GB memory.. for some reason.. on any new apps > i > install.. it seems the shortcuts dont get created.. often it will create > the > folder for them, but no icons.. > > Has anyone run into this and know of a fix? > > Thanks |
| | RE: Vista installation of various programs issue.. shortcuts not creat Hey there Markm, Those apps generally don't wind up creating any Desktop or Start Menu icons because those folders are located in a different location than XP. (XP-Documents and Settings\%username% where Vista is - Users\%username%) You can always manually create the shortcuts by locating the app in the Program Files (x86) directory. Just right click on the desktop, click New>Shortcut>and then browse to the location of the app. Kind of a pain, but the 'legacy' apps usualy look for the above pathing and just can't find it. Best Regards, Will "markm75" wrote: Quote: > I'm running vista x64 with 4GB memory.. for some reason.. on any new apps i > install.. it seems the shortcuts dont get created.. often it will create the > folder for them, but no icons.. > > Has anyone run into this and know of a fix? > > Thanks |
| | Re: Vista installation of various programs issue.. shortcuts not c "Mark L. Ferguson" wrote: Quote: > Right click, an Command Prompt shortcut, 'run as administrator' > End task on 'Explorer' in Task Manager > At the prompt, go to C:\Users\<user>\AppData\Local > atrib -h IconCache.db > del IconCache.db > start explorer (or restart Windows) > > -- > Was this helpful? Then click the Ratings button. Voting helps the web > interface. > http://www.microsoft.com/wn3/locales...eAPostAsAnswer > Mark L. Ferguson > . > > "markm75" <markm75@xxxxxx> wrote in message > news:6FA0E11C-8DA8-4C21-A0FB-845AD77CEE60@xxxxxx Quote: > > I'm running vista x64 with 4GB memory.. for some reason.. on any new apps > > i > > install.. it seems the shortcuts dont get created.. often it will create > > the > > folder for them, but no icons.. > > > > Has anyone run into this and know of a fix? > > > > Thanks db.. i did a rename.. which i'm assuming should have worked as well.. after rebooting in fact.. tried another install.. i still have just the program files directory created, but empty for icons.. |
| | RE: Vista installation of various programs issue.. shortcuts not c "William Anderson" wrote: Quote: > Hey there Markm, > > Those apps generally don't wind up creating any Desktop or Start Menu icons > because those folders are located in a different location than XP. > (XP-Documents and Settings\%username% where Vista is - Users\%username%) > > You can always manually create the shortcuts by locating the app in the > Program Files (x86) directory. Just right click on the desktop, click > New>Shortcut>and then browse to the location of the app. Kind of a pain, but > the 'legacy' apps usualy look for the above pathing and just can't find it. > > Best Regards, > > Will > > "markm75" wrote: > Quote: > > I'm running vista x64 with 4GB memory.. for some reason.. on any new apps i > > install.. it seems the shortcuts dont get created.. often it will create the > > folder for them, but no icons.. > > > > Has anyone run into this and know of a fix? > > > > Thanks identical and identically configured machine at work, where if i run an install the icons are created just fine.. For instance.. two apps in particular.. i installed the latest real player.. on my machine which is fine.. it created the folder and icons just fine, whereas on the corrupt machine.. only the main folder gets made. I did the same test with the "super" move converter program, the same results occurred. Some of the programs i'm installing, like Studio 11, have quite a few icons that get made for them, so its not practical to just manually create them. I feel there is a glitch here but dont know what to look for. Thanks |
| | #6 (permalink) |
| | RE: Vista installation of various programs issue.. shortcuts not c I should add, that its the path C:\ProgramData\Microsoft\Windows\Start Menu\Programs where the folders get created, but no icons.. |
| | #7 (permalink) |
| | RE: Vista installation of various programs issue.. shortcuts not c You bring up an interesting point regarding the 32-bit installs. I still think that it's got something to do with the x64 OS. I'll go ahead and install some 32bit apps with verbose logging and let you know what i see. Is there a program (specifically non microsoft) that you're looking for? "markm75" wrote: Quote: > I should add, that its the path C:\ProgramData\Microsoft\Windows\Start > Menu\Programs where the folders get created, but no icons.. |
| | #8 (permalink) |
| | RE: Vista installation of various programs issue.. shortcuts not c "William Anderson" wrote: Quote: > You bring up an interesting point regarding the 32-bit installs. I still > think that it's got something to do with the x64 OS. I'll go ahead and > install some 32bit apps with verbose logging and let you know what i see. Is > there a program (specifically non microsoft) that you're looking for? > > "markm75" wrote: > Quote: > > I should add, that its the path C:\ProgramData\Microsoft\Windows\Start > > Menu\Programs where the folders get created, but no icons.. like i said even programs like the real player or the super movie converter.. I also installed Pinnacle 11.5 and the icons werent made there either. Obviously this must be some sort of registry or file system glitch perhaps security related. I checked security permissions on the start menu under program data but didnt see anything out of the ordinary. |
| | #9 (permalink) |
| | RE: Vista installation of various programs issue.. shortcuts not c Hey there Markm, It's very possible that the registry structure or file structure of the OS differs between x64 and x32 systems...preventing the icons from being deposited in their correct locations. I'll run the installers and see what happens. However, remember that although Vista x64 supports 32-bit applications, (they have to since manufacturers seem to be dragging their butts in the 64-bit world.) there's no guarantee of complete functionality. Ultimately, the way the Installer for the application plays a big role in how it installs on the 64-bit platform. So if the package was created before Vista 64 came into play, things like this are possible to happen. Once again, I'll run a couple of those apps that you mentioned, and let you know where I see it fail. :-) Best Regards, Will "markm75" wrote: Quote: > > > "William Anderson" wrote: > Quote: > > You bring up an interesting point regarding the 32-bit installs. I still > > think that it's got something to do with the x64 OS. I'll go ahead and > > install some 32bit apps with verbose logging and let you know what i see. Is > > there a program (specifically non microsoft) that you're looking for? > > > > "markm75" wrote: > > Quote: > > > I should add, that its the path C:\ProgramData\Microsoft\Windows\Start > > > Menu\Programs where the folders get created, but no icons.. > There doesnt seem to be any specific program that doesnt put the icons in.. > like i said even programs like the real player or the super movie converter.. > I also installed Pinnacle 11.5 and the icons werent made there either. > > Obviously this must be some sort of registry or file system glitch perhaps > security related. I checked security permissions on the start menu under > program data but didnt see anything out of the ordinary. > > |
| | #10 (permalink) |
| | RE: Vista installation of various programs issue.. shortcuts not c "William Anderson" wrote: Quote: > Hey there Markm, > > It's very possible that the registry structure or file structure of the OS > differs between x64 and x32 systems...preventing the icons from being > deposited in their correct locations. I'll run the installers and see what > happens. > > However, remember that although Vista x64 supports 32-bit applications, > (they have to since manufacturers seem to be dragging their butts in the > 64-bit world.) there's no guarantee of complete functionality. > > Ultimately, the way the Installer for the application plays a big role in > how it installs on the 64-bit platform. So if the package was created before > Vista 64 came into play, things like this are possible to happen. > > Once again, I'll run a couple of those apps that you mentioned, and let you > know where I see it fail. :-) > > Best Regards, > > Will > > "markm75" wrote: > Quote: > > > > > > "William Anderson" wrote: > > Quote: > > > You bring up an interesting point regarding the 32-bit installs. I still > > > think that it's got something to do with the x64 OS. I'll go ahead and > > > install some 32bit apps with verbose logging and let you know what i see. Is > > > there a program (specifically non microsoft) that you're looking for? > > > > > > "markm75" wrote: > > > > > > > I should add, that its the path C:\ProgramData\Microsoft\Windows\Start > > > > Menu\Programs where the folders get created, but no icons.. > > There doesnt seem to be any specific program that doesnt put the icons in.. > > like i said even programs like the real player or the super movie converter.. > > I also installed Pinnacle 11.5 and the icons werent made there either. > > > > Obviously this must be some sort of registry or file system glitch perhaps > > security related. I checked security permissions on the start menu under > > program data but didnt see anything out of the ordinary. > > > > the work machine which is x64 works fine.. its a sudden change for some reason... |
| Files become shortcuts when placed in programs folder | General Discussion | |||
| Running Programs Through Task Scheduler Shortcuts | System Security | |||
| Start/All Programs Menu shortcuts not working | Vista General | |||
| Deleting shortcuts from desktop of uninstalled programs | Vista General | |||
| Shortcuts not working for some programs | Vista General | |||
