| | Problem with extended desktop to multiple monitors when screen saver comes on I have a Vista Ultimate laptop connected to two monitors. I can extend my desktop to the second monitor just fine. But when I come back from a meeting, and my screen saver has been on, my desktop is no longer extended. Both monitors show the display for monitor 1. The setting is still correct under Display settings and I can fix the issue by changing Monitor 2 to be the main monitor and then switching it back to Monitor 1 being the main monitor. Has anyone else had this problem? Is there a known fix? |
| | Re: Problem with extended desktop to multiple monitors when screen saver comes on Have you checked to be sure you have the latest video drivers installed? "cyrus" <cyrus@xxxxxx> wrote in message news:09541E3B-9203-4FCA-8D51-450C079D6D73@xxxxxx Quote: >I have a Vista Ultimate laptop connected to two monitors. I can extend my >desktop to the second monitor just fine. But when I come back from a >meeting, and my screen saver has been on, my desktop is no longer extended. >Both monitors show the display for monitor 1. > > The setting is still correct under Display settings and I can fix the > issue by changing Monitor 2 to be the main monitor and then switching it > back to Monitor 1 being the main monitor. > > Has anyone else had this problem? Is there a known fix? |
| | Re: Problem with extended desktop to multiple monitors when screen saver comes on "cyrus" <cyrus@xxxxxx> wrote in message news:09541E3B-9203-4FCA-8D51-450C079D6D73@xxxxxx Quote: >I have a Vista Ultimate laptop connected to two monitors. I can extend my >desktop to the second monitor just fine. But when I come back from a >meeting, and my screen saver has been on, my desktop is no longer extended. >Both monitors show the display for monitor 1. > > The setting is still correct under Display settings and I can fix the > issue by changing Monitor 2 to be the main monitor and then switching it > back to Monitor 1 being the main monitor. > > Has anyone else had this problem? Is there a known fix? I have noticed that I have do swap the monitors over depending on what OS installation I am using. It seems to happen randomly, and has really annoyed me. I use desktop monitors, with UltraMon, which allows you to turn off the secondary monitor, or swap them around very quickly. www.ultramon.com ss. |
| | Re: Problem with extended desktop to multiple monitors when screen saver comes on It does seem to be working better after upgrading the drivers. Thanks for the idea. Cyrus "Colin Barnhorst" <c.barnhorst@xxxxxx> wrote in message news:2EF4E959-BAEC-4C9F-84B6-C27061B8F11A@xxxxxx Quote: > Have you checked to be sure you have the latest video drivers installed? > > "cyrus" <cyrus@xxxxxx> wrote in message > news:09541E3B-9203-4FCA-8D51-450C079D6D73@xxxxxx Quote: >>I have a Vista Ultimate laptop connected to two monitors. I can extend my >>desktop to the second monitor just fine. But when I come back from a >>meeting, and my screen saver has been on, my desktop is no longer >>extended. Both monitors show the display for monitor 1. >> >> The setting is still correct under Display settings and I can fix the >> issue by changing Monitor 2 to be the main monitor and then switching it >> back to Monitor 1 being the main monitor. >> >> Has anyone else had this problem? Is there a known fix? |
| | Re: Problem with extended desktop to multiple monitors when screen saver comes on THE THREE MAIN WAYS TO SETUP MULTIPLE MONITORS 1) You can buy a pre-manufactured multi-monitor computer. The best place to purchase a 'multiple monitor computer' (http://www.multi-monitors.com/SUPER_...n_PCs_s/23.htm) is at: 'Multi-Monitors.com' (http://Multi-Monitors.com). They carry a multi-monitor computer line called 'SUPER PC' (http://www.super-pc.com) that can support from 2 to 16 monitors. 'Multi-Screen Computer Systems' (http://www.multi-monitors.com/SUPER_...s_PCs_s/23.htm) 'Multiple Monitor LCD Displays' (http://www.multi-monitors.com/SUPER_...plays_s/21.htm) 2) You can get a 'USB to VGA Adapter' (http://www.multi-monitors.com/product_p/usbvga1.htm), or ' USB to DVI Adapter' (http://www.multi-monitors.com/USB_to..._p/usbdvi1.htm) that will allow you to add an extra monitor to your computer via any USB2.0 Port. You can also add multiple extra monitors by using multiple adapters. This is a great option for viewing documents, surfing the web, using Microsoft Office and many other business tasks. This is not a good option for intense graphical situations such as HDTV, Blu-ray, Gaming and 3D / CAD Workstation applications. For those types of scenarios, it is highly recommended that you purchase a high-powered multi-monitor workstation or a 'Matrox Dual or Triple Head2Go' (http://www.multi-monitors.com/category_s/5112.htm). 'Multi-Monitor Adapters' (http://www.multi-monitors.com/SUPER_...pters_s/22.htm) 3) You can replace or add an extra video card to your existing computer, depending on how many monitors you wish to support. Although this sounds easy enough, this is a rather complex solution for a beginner, especially when trying to find a compatible graphics card. For this reason, I am going to write an entirely seperate post on that topic and will link to it here, very soon. 'Multi-Monitor Video Cards' (http://www.multi-monitors.com/category_s/1914.htm) Once you have your multiple monitor system set up and ready to use, you will need to enable all of your monitors in your “Display Properties” Control Panel. Here is a great link to a complete and animated walkthrough of how to enable your multiple monitors in Windows. 'How to Setup Multiple Monitors (Instructions)' (http://www.multi-monitors.com/SUPER_...tions_s/40.htm) This is what it will look like when you are done: 'Multi-Monitor Video Demo 1' (http://www.youtube.com/watch?v=j_avGStqZOI) 'Multi-Monitor Video Demo 2' (http://www.youtube.com/watch?v=1AR7WDpCXj4) -- techgeek2 ------------------------------------------------------------------------ techgeek2's Profile: http://forums.techarena.in/members/121480.htm View this thread: http://forums.techarena.in/vista-help/955572.htm http://forums.techarena.in |
| Problem with extended desktop to multiple monitors when screen saver comes on | Vista hardware & devices | |||
| Screen Saver Multiple problem | Vista General | |||
| Vista screen saver for dual monitors | Vista General | |||
| Enabling extended desktop with multiple monitors doesn't work | Vista hardware & devices | |||
| Screen Saver (Photos) on Dual Monitors | Vista General | |||
