Vista - Wrong log in ID on remote desktop connection
Old 04-25-2008   #1 (permalink)
Tony29
The remote desktop from my W/Vista Ultimate to a W/2003 Server works fine,
but ...
when I get the login prompt from the remote computer it is prefilled with
<ip address>\<username> rather than simply <username>.
This wasn't previously occuring from my W/XP Pro client which would
correctly result in the login prompt being simply <username>
How do I get the login prompt to be correct when I'm using W/Vista Ultimate
as my remote desktop client?
Tony
invalid connection file on remote desktop connection Vista General
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
RDC(Remote Desktop Connection) Vista networking & sharing
remote desktop connection? AKA remote access? Vista General
