| | Customize System Restore intervals I did a registry tweak to change automatic restore points to every two days instead of every 24 hours but it didn't work. Anyone know what could be wrong? -- Message posted via http://www.windowskb.com |
| | RE: Customize System Restore intervals I don't know about the registry tweak but the system restore interval is set by the task scheduler and you can modify it there. -- Paul "jimb11 via WindowsKB.com" wrote: Quote: > I did a registry tweak to change automatic restore points to every two days > instead of every 24 hours but it didn't work. Anyone know what could be wrong? > > > -- > Message posted via http://www.windowskb.com > > |
| System Restore: do restore points persist after a restore? | Vista General | |||
| Customize Vista's System Restore? | Vista General | |||
| Customize Vista's System Restore? | Vista file management | |||
| Customize Vista's System Restore? | Vista performance & maintenance | |||
| system restore not creating system restore everyday | Vista General | |||
