Vista - Problem setting default printer in Vista
Old 04-27-2008   #1 (permalink)
DH NYC
When I attempt to install ANY print driver in Vista Ultimate, I have the
following problem:
1) The printer cannot be set as a default in my administrator account. When
I select "Set as default printer" through "Control Panel", nothing happens.
2) When I attempt to print a PDF or photo, the printer is not recognized at
all.
3) I CAN print from Word, etc., but must select the printer each time from
the drop down menu.
4) Oddly, the printer automatically sets as my default in my "Guest" account
when I install the driver. All funtionality works fine in the guest account.
I have checked all the various permissions and cannot determine why I
cannnot select a printer as my default in my administrator account.
Any ideas out there? Thanks!
Old 04-28-2008   #2 (permalink)
Vista Ultimate 32bit
Re: Problem setting default printer in Vista
remove all other virtual printers and keep only your printer.
Old 05-05-2008   #3 (permalink)
DH NYC
Tried that, but even as the only printer option this "can't set a default"
problem still occurs.
"ahmad12" wrote:
> ahmad12
Setting a default printer for the DEFAULT USER Vista print fax & scan
vbscript to cahnge default printer setting from color to b&w VB Script
Vista machine not holding default printer setting. Vista print fax & scan
Setting default printer Vista installation & setup
Setting Default Printer to Stay Vista hardware & devices
