| | Monitor resolution I just setup my new computer, a Dell 530 with Vista. I have connected my not-that-old monitor. I get the message that the monitor workes best at 1680 x 1050 resolution. I try to select this resolution from the display > personalize > display settings, but this setting is not available. When I choose other settings the photos seem distorted (too wide). The help article talks about being able to let Vista choose the best monitor resoultion but is not clear on how to do this or on how to restore the default settings. Help would be appreciated. Thanks in advance, Jim |
| | Re: Monitor resolution Hi, Have you checked for an update to the display adapter driver? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Jim McGivney" <mcgivney@xxxxxx> wrote in message news:1BBC8EBB-BF50-4A3C-858A-53FF37C7F4DD@xxxxxx Quote: >I just setup my new computer, a Dell 530 with Vista. I have connected my >not-that-old monitor. I get the message that the monitor workes best at >1680 x 1050 resolution. I try to select this resolution from the display > >personalize > display settings, but this setting is not available. When I >choose other settings the photos seem distorted (too wide). The help >article talks about being able to let Vista choose the best monitor >resoultion but is not clear on how to do this or on how to restore the >default settings. Help would be appreciated. > Thanks in advance, > Jim |
| | Re: Monitor resolution /Clear Windows/ said: Quote: > > "Bruce Chambers" <bchambers@xxxxxx> wrote in message > news:eWmT9#JqIHA.3652@xxxxxx Quote: >> Jim McGivney wrote: Quote: >>> I just setup my new computer, a Dell 530 with Vista. I have connected my >>> not-that-old monitor. I get the message that the monitor workes best at >>> 1680 x 1050 resolution. I try to select this resolution from the display >>> > personalize > display settings, but this setting is not available. >>> When I choose other settings the photos seem distorted (too >>> wide). The help article talks about being able to let Vista choose the >>> best monitor resoultion but is not clear on how to do this or on how to >>> restore the default settings. Help would be appreciated. >>> Thanks in advance, >>> Jim >> The problem is that your new computer doesn't include a video adapter >> capable of properly supporting that specific resolution. Your options are >> somewhat limited at this point. You can either replace (downgrade, in >> effect - your current monitor is of a higher grade than the computer's >> components) the monitor with something that the computer's video adapter >> can support, or you can upgrade the computer with a better quality video >> adapter. I'd go with the latter option, personally. >> >> The problem is that your new computer doesn't include a video adapter >> capable of properly supporting that specific resolution. > This it totally incorrect!!! Read my reply to the OP. to the original questioner in this thread. It is possible however that a different driver will enable the 1680X1050 resolution desired, or that running the monitor from the VGA, instead of the DVI connector (if so equipped), will enable the resolution. Visit the chip or card manufacturer's WEBsite for drivers. Both suggestions have worked here in different instances, when at first a widescreen resolution such as 1680X1050 was not initially available on this dated video card. |
| | Re: Monitor resolution it is incorrect. read here hello... you need to supply to vista the monitor driver that is usually a small ".inf" type file that tells vista the exact make and specifications of your monitor. You can look on the disk that came with your monitor, or you can look on the website of the manufacturer of the monitor. If you cant find it, post the brand and model number of the monitor and ill find it for you <dev@xxxxxx> wrote in message news:uBX3dxMqIHA.4112@xxxxxx Quote: > /Clear Windows/ said: Quote: >> >> "Bruce Chambers" <bchambers@xxxxxx> wrote in message >> news:eWmT9#JqIHA.3652@xxxxxx Quote: >>> Jim McGivney wrote: >>>> I just setup my new computer, a Dell 530 with Vista. I have connected >>>> my >>>> not-that-old monitor. I get the message that the monitor workes best >>>> at >>>> 1680 x 1050 resolution. I try to select this resolution from the >>>> display >>>> > personalize > display settings, but this setting is not available. >>>> When I choose other settings the photos seem distorted (too >>>> wide). The help article talks about being able to let Vista choose the >>>> best monitor resoultion but is not clear on how to do this or on how to >>>> restore the default settings. Help would be appreciated. >>>> Thanks in advance, >>>> Jim >>> >>> The problem is that your new computer doesn't include a video adapter >>> capable of properly supporting that specific resolution. Your options >>> are >>> somewhat limited at this point. You can either replace (downgrade, in >>> effect - your current monitor is of a higher grade than the computer's >>> components) the monitor with something that the computer's video adapter >>> can support, or you can upgrade the computer with a better quality video >>> adapter. I'd go with the latter option, personally. >>> >>> The problem is that your new computer doesn't include a video adapter >>> capable of properly supporting that specific resolution. >> This it totally incorrect!!! Read my reply to the OP. > Actually, what Bruce stated is correct, and I see no response from you > to the original questioner in this thread. > > It is possible however that a different driver will enable the 1680X1050 > resolution desired, or that running the monitor from the VGA, instead of > the DVI connector (if so equipped), will enable the resolution. Visit > the chip or card manufacturer's WEBsite for drivers. > > Both suggestions have worked here in different instances, when at first > a widescreen resolution such as 1680X1050 was not initially available on > this dated video card. |
| Monitor Resolution | Graphic cards | |||
| Monitor Resolution Problem | Vista General | |||
| Monitor resolution | Vista General | |||
| Monitor resolution | Vista hardware & devices | |||
