Vista - fax does not use IE dial 9 settings
Old 04-29-2008   #1 (permalink)
Chris Varz
Hi all
I am having a problem with windows ultimate and the windows fax utility. The windows fax software is is not using my location IE dial 9 for outside line, I can get it to work manually but it will not default to the dial 9 option. Any ideas? Thank you in advance for your help
Old 04-29-2008   #2 (permalink)
Gary Mount
Re: fax does not use IE dial 9 settings
There is a Vista fax newsgroup you could try instead of this general
newsgroup.
"Chris Varz" wrote in message news:200842955310xmlmagician@xxxxxx
Quote:
> Hi all
dial up connection box appears even though all dial up connections Live Mail
Cannot open Theme Settings, Display Settings, Screen Saver Settings, etc Vista performance & maintenance
Solved Need Help. Vista Dial-up stuck, Can not dial-up Network & Sharing
Clearing IP settings: duplicate ip settings and blank ip settings Vista networking & sharing
Clearing IP settings: duplicate ip settings and blank ip settings Vista General
