| | ATI1650 Pro problems Whether it's a coincidence or not (?) but since around the time I installed SP1 Home Premium I am getting this message at random times -- Display driver atikmdag stopped responding and has successfully recovered. The screen goes blank for a second or 2 and then comes back again. Is this a driver issue or is there some other underlying problem? When it's running, I get no problems at all. First time I noticed it was using Easy Media Creator to convert an avi to a dvd and evrytime it happens, it goes back to the start and just keeps doing it. Just had it happen during a game but once it had recovered, the game just carried on playing!! Any thughts or suggestions for a different forum for help? TIA cheers, Len |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| VPC problems over AMD. Internet problems: bad request, error 400 | Virtual PC | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
