Vista - Program Loading Problem.
Old 04-29-2008   #1 (permalink)
Brian
I am trying to instal CorelDraw X3 on to my newly aquired Vista Ultimate OS.
This prog worked ok with Windows XP, but now,after loading a few files,
stops, with the message
"Default Feature
Component
Catastrophic Failure"
Any help greatly appreciated.
Old 04-29-2008   #2 (permalink)
Mick Murphy
RE: Program Loading Problem.
Two things to try.
1 Right-click on its setup.exe>Run as Admin
2.Right-click on its setup.exe>Properties>Compatibility Tab> install in XP
SP2 mode
Mick Murphy - Qld - Australia
> "Default Feature
> Component
Old 04-29-2008   #3 (permalink)
Mark
Re: Program Loading Problem.
I heard there were compatibility issues with CorelDraw X3 and Vista. Not
positive.
Mark
"Brian" <ballen262@xxxxxx> wrote in message
newsF6D105E-85DD-41AD-A25A-EB0198DFE580@xxxxxx
>OS. This prog worked ok with Windows XP, but now,after loading a few
>files, stops, with the message
> "Default Feature
> Component
Click on program, sticks on loading, doesnt open Vista General
loading a new program in my new computer Vista General
Removed Startup Program Keeps Loading Vista General
Problem while loading Vista installation & setup
