Vista - iso filoe too big for dvd, how do i split it to put it on 2 dvds?
Old 04-29-2008   #1 (permalink)
brando132
i got an iso file that 6 gigs but the biggest dvd-/+rw i can find is 4.7
gigs, what do i do to put the fil on 2 dvds so it will work?
Old 04-29-2008   #2 (permalink)
Windows Vista Ultimate X64 SPII
Re: iso filoe too big for dvd, how do i split it to put it on 2 dvds?
Either compress it using WinZip or WinRar.
I don't know what is in this ISO but that's all I can think of.
Hope this helps
Old 04-29-2008   #3 (permalink)
Tom Lake
"brando132" <brando132@xxxxxx> wrote in message
news765768C-C39E-4CEE-876E-BB38BEC2E261@xxxxxx
You'll have to get a Dual Layer DVD drive and use DL disks with it.
a DL disk can hold 8.5 GB. Search for dual layer DVD online and you can
find them for about $30.00-$35.00 and about $2.00-$3.00 for blank disks.
Tom Lake
Old 04-29-2008   #4 (permalink)
damn, I never thought of that ..lmao good answer Tom
Old 04-29-2008   #5 (permalink)
NetBiznessMan
They make what's called a double sided DVD, it has a capacity of 9.4 Gigs.
Your player / recorder will have to support them though or they won't work.
They look like any other DVD, their just able to hold more on them then 1st
generation DVD's.
NetBiznessMan
Old 04-30-2008   #6 (permalink)
Gary Mount
You have made the mistake of doubling the 4.7 GB capacity of single layer
DVDs to calculate a capacity of 9.4 GB.
The DL disks only hold 8.5 GB.
"NetBiznessMan" <NetBiznessMan@xxxxxx> wrote in message
news:eaapOMnqIHA.4912@xxxxxx
> work. They look like any other DVD, their just able to hold more on them
> then 1st generation DVD's.
> NetBiznessMan
Old 04-30-2008   #7 (permalink)
Gary Mount
You could mount the .iso file using a program such as "alcohol".
(http://www.alcohol-soft.com/). I use the free version called Alchohol 52%
that works with Vista.
This software creates a virtual drive from the .iso file just as if you had
burned the file to a disk and inserted the disk into the drive.
Old 04-30-2008   #8 (permalink)
NetBiznessMan
"Gary Mount" <gary_mount@xxxxxx> wrote in message
news:O0jL#IoqIHA.3616@xxxxxx
>> Gigs. Your player / recorder will have to support them though or they
>> won't work. They look like any other DVD, their just able to hold more on
>> them then 1st generation DVD's.
>> NetBiznessMan
Well if you want to get technical it's 8.74 GiB. For marketing there listed
in GB making it 9.4
NetBiznessMan
Old 04-30-2008   #9 (permalink)
Gary Mount
Disk Type number of sectors capacity in capacity
capacity
for data (2,048B each) bytes in GB
in GiB
DVD-R (SL) 2,298,496 4,707,319,808 4.7
4.384
DVD+R (SL) 2,295,104 4,700,372,992 4.7 4.378
DVD-R DL 4,171,712 8,543,666,176 8.5
7.957
DVD+R DL 4,173,824 8,547,991,552 8.5 7.961
news:ewfzwUoqIHA.1736@xxxxxx
>>>> 4.7
>>> on them then 1st generation DVD's.
>>> NetBiznessMan
> listed in GB making it 9.4
> NetBiznessMan
Old 04-30-2008   #10 (permalink)
ray
Re: iso filoe too big for dvd, how do i split it to put it on 2dvds?
>> 4.7 gigs, what do i do to put the fil on 2 dvds so it will work?
> NetBiznessMan
That's double layer or dual layer - not doulbe sided - it still only uses
one side.
split textbox VB Script
Ignores BR/DVDs or DVDs but CDs works fine. Vista hardware & devices
Split Screen Vista file management
Are volume licensing upgrade DVDs bootable?--they do not ship full DVDs. Vista General
