Vista - IDT audio through MS update: no audio!
Old 05-01-2008   #1 (permalink)
omissis
Hi all
My computer: Dell dimension 9200, Vista HP 32bit
Chipset: Intel P965
Audio: Sigmatel
Hardware ID for the audio device:
HDAUDIO\FUNC_01&VEN_8384&DEV_7618&SUBSYS_102801DB&REV_1002
Problem: I wasn't able to download the SP1 update because of audio drivers'
incompatibility; yesterday MS update proposed me the update to IDT-audio
drivers version 6.10.5609, downloaded them.
Result: no audio, device Manager showing Code 10 error.
I tried twice again until I decided to completely remove the Sigmatel audio
drivers and restart with default Microsoft drivers version 6.0.6000.16386.
Now, the audio turned on again but, at the same time, WU notifies that the
SP1 is avaliable with update chronology showing the IDT-audio update that
didn't succeed.
What should I do now? Try to install SP1?
Thx for any suggestion
Old 05-01-2008   #2 (permalink)
Stuart Sabatini
Re: IDT audio through MS update: no audio!
I installed same update, what a mistake. Not only did my audio not work,
but I could not start control panel from the start menu. Using windows
explorer I was able to get to windows updates, but I could not get to the
uninstall page. I used system restore to correct the problem.
Stuart
"omissis" <omissis@xxxxxx> wrote in message
news:77AEDCFD-2060-4927-B40A-A085ACBD5547@xxxxxx
Quote:
> Hi all
> Chipset: Intel P965
> Audio: Sigmatel
> drivers'
> audio
> didn't succeed.
Old 05-01-2008   #3 (permalink)
kurttrail
Stuart Sabatini wrote:
> work, but I could not start control panel from the start menu. Using
> windows explorer I was able to get to windows updates, but I could not
> get to the uninstall page. I used system restore to correct the
> problem.
This should teach ya'll to never trust driver updates from MS.
Either they are dumbed-down to minimalistic functions, or they just
bugger up your install. It ain't worth the risk.
Peace!
Kurt
Former Self-anointed Moderator
microscum.pubic.windowsexp.gonorrhea
"Produkt-Aktivierung macht frei!"
How do I get audio file format in audio filter driver? Vista music pictures video
IDT Audio CODEC update reappears after successful update Vista General
Audio drivers for Intel Sigmatel onboard audio Vista hardware & devices
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur Vista hardware & devices
