| | Problem opening zip files For a short time I had installed pkzip. It is now uninstalled, but apparantly has left Windows Explorer as the program used to open zip files. When I click on a zip file, Windows explorer opens, closes, opens, closes ad infinitum. Only recourse is to force a reboot. I would like to change the default opens with ... to something that works. I see that on my XP computer the recommended program for opening zip files is called "Compressed (zip) Folders". I can't find such a program on Vista. Also, the only recommended program showing up on Vista "Open With" is Windows Explorer, which I know is a disaster. I can right-click and select Extract All to work around this problem, but would like to get the Open function working correctly. Help appreciated. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Problem opening zip files For a short time I had installed pkzip. It is now uninstalled, but apparantly has left Windows Explorer as the program used to open zip files. When I click on a zip file, Windows explorer opens, closes, opens, closes ad infinitum. Only recourse is to force a reboot. I would like to change the default opens with ... to something that works. I see that on my XP computer the recommended program for opening zip files is called "Compressed (zip) Folders". I can't find such a program on Vista. Also, the only recommended program showing up on Vista "Open With" is Windows Explorer, which I know is a disaster. I can right-click and select Extract All to work around this problem, but would like to get the Open function working correctly. Help appreciated. You might try this tutorial to restore the default built-in ZIP handler in Vista to see if it will help you. http://www.vistax64.com/tutorials/65...ile-vista.html A great free ZIP program to use is 7-Zip. You might give it a try to see what you think. 7-Zip Shawn |
| | Re: Problem opening zip files "dickey38" <dickey38@xxxxxx> wrote in message news:6742BF69-A6A5-4E35-AC7C-1D58AE07B17E@xxxxxx Quote: > For a short time I had installed pkzip. It is now uninstalled, but > apparantly has left Windows Explorer as the program used to open zip > files. > When I click on a zip file, Windows explorer opens, closes, opens, closes > ad > infinitum. Only recourse is to force a reboot. > > I would like to change the default opens with ... to something that works. > I see that on my XP computer the recommended program for opening zip files > is > called "Compressed (zip) Folders". I can't find such a program on Vista. > Also, the only recommended program showing up on Vista "Open With" is > Windows > Explorer, which I know is a disaster. > > I can right-click and select Extract All to work around this problem, but > would like to get the Open function working correctly. > > Help appreciated. > program to open a zip file, otherwise, it's going to open with WE if something else is not there in the list. My list to choose from is IE, WinRAR and Winzip with WinRAR being the default used to open a zip file. Without either one of the zip programs there, it was going to IE on my machine and Vista went into the shake, rattle and roll too. |
| Problem opening .ini files. | .NET General | |||
| office 2004 for Mac/ problem opening files | .NET General | |||
| opening files | Vista music pictures video | |||
| Problem opening .rtf files with ms works | Vista General | |||
| Navigation When Saving Files, and Opening mht files from Browser | Vista file management | |||
