Vista - System Restore
Old 05-02-2008   #1 (permalink)
Sue
System Restore
I get this message when I try system restore after - it appears to be
complete - in other words it finds a restore point, I agree and it does its
thing. Just when everything is restarted the error message is that System
restore was not successful due to an "unexpected error". I have a new Dell
laptop running Vista Home Premium (SP1 has not downloaded yet) and Norton
Internet Security 2007 and Spybot latest version. I tell you this because on
my old XP desktop I had to change a setting on NAV to enable system restore
to work and once I did that everything was fine. -
Thanks for your help/ideas
Old 05-02-2008   #2 (permalink)
Mark
Re: System Restore
I received the same error. Googled a bit and found that you need to
reboot in to safe mode then rum system restore. After doing that it worked
for me.
Good luck.
Old 05-02-2008   #3 (permalink)
Mark L. Ferguson
Re: System Restore
You may have to completely turn off NAV to do it.
Also look at:
Restoration Incomplete. Your computer cannot be restored . . .:
http://bertk.mvps.org/html/symantecdoc1.html
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Sue" <Sue@xxxxxx> wrote in message
news:9A5C8B87-29A0-4D62-B91A-A83B1681678D@xxxxxx
> its
> Dell
> on
> restore
Old 05-02-2008   #4 (permalink)
Sue
RE: System Restore
Next time I need system restore Ill ty this. Dell tech support helped me
last night but this is exactly the sttting I was looking for and could not
fine on my new Norton. Thanks
Old 05-02-2008   #5 (permalink)
Mark
Re: System Restore
Any info on disabling this on Norton 360 v2.0 ? Can't seem to find it with
this Norton product.
Thanks.
Old 05-02-2008   #6 (permalink)
Mark L. Ferguson
Re: System Restore
Click here : http://www.symantec.com/norton/suppo...um_support.jsp
Norton 360 2.0 claims to have included email and live chat support.
interface.
Mark L. Ferguson
"Mark" <steelerdukREMOVE@xxxxxx> wrote in message
news:eo#mYvFrIHA.5940@xxxxxx
> with this Norton product.
> Thanks.
Old 05-02-2008   #7 (permalink)
Mark
Re: System Restore
Here's an update to those that may need to know. If you are running Norton
360 2.0 then ( to be able to run Vista system restore correctly ) you need
to disable the firewall protection within Norton 360 2.0.
Thanks Mark for the heads up as this was the information I received from
Norton support chat.
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
