| Guest | problem caused usb to serial cable radio shack I was using windows xp , now i chenged to vista,,,but ,,,have aproblem usb serial cable radio shack is not working on vista bit-32....any sugeston? |
| Guest | Re: problem caused usb to serial cable radio shack It's very likely that there is no problem with the cable or the serial port. It's probably the need for a better driver for the device that is using the serial port.. A driver that is compatible with Vista. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "irma" <irma@xxxxxx> wrote in message news F4E55AD-216F-4F06-8F0C-A5E3049A780F@xxxxxxQuote: > I was using windows xp , now i chenged to vista,,,but ,,,have aproblem > usb > serial cable radio shack is not working on vista bit-32....any sugeston? |
| Guest | Re: problem caused usb to serial cable radio shack what protocol is it using to connect (you may need to enable telnet) "irma" <irma@xxxxxx> wrote in message news F4E55AD-216F-4F06-8F0C-A5E3049A780F@xxxxxxQuote: >I was using windows xp , now i chenged to vista,,,but ,,,have aproblem usb > serial cable radio shack is not working on vista bit-32....any sugeston? |
| Guest | Re: problem caused usb to serial cable radio shack "irma" <irma@xxxxxx> wrote in message news F4E55AD-216F-4F06-8F0C-A5E3049A780F@xxxxxxQuote: >I was using windows xp , now i chenged to vista,,,but ,,,have aproblem usb > serial cable radio shack is not working on vista bit-32....any sugeston? |
| Guest | Re: problem caused usb to serial cable radio shack "William" <wdavidson@xxxxxx> wrote in message news:F426A8EE-8F55-4012-B17F-492EE1DFE3C0@xxxxxx Quote: > what protocol is it using to connect (you may need to enable telnet) > "irma" <irma@xxxxxx> wrote in message > news F4E55AD-216F-4F06-8F0C-A5E3049A780F@xxxxxxQuote: >>I was using windows xp , now i chenged to vista,,,but ,,,have aproblem >>usb >> serial cable radio shack is not working on vista bit-32....any sugeston? |
| USB TO SERIAL 232 NULL CABLE | Vista General | |||
| Windows Vista - Need a USB to serial port cable... | Vista hardware & devices | |||
| Problem caused by Serial ATA Storage Controller Driver | Vista General | |||
| This problem was caused by Ati2evxx.exe Help anyone? | Vista General | |||
