| | #11 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC On Thu, 8 May 2008 09:01:40 -0500, Andrew Rossmann <andysnewsreply@xxxxxx_junk.comcast.net> wrote: Quote: >In article <kt352418du5dm4fsogqdcdsr4fq7hap8o5@xxxxxx>, >orthocross@xxxxxx says... Quote: >> On Wed, 7 May 2008 17:00:04 -0700, jimmy >> <jimmy@xxxxxx> wrote: >> Quote: >> >Same thing happened to me. I just went back to the old driver and everything >> >was fine. Not sure why it did what it did >> This optional update was also offered to me last week. Knowing my >> audio is not "IDT", I simply right-clicked on it and put a check-mark >> beside "Hide". >In 2006, IDT took over the audio codec chip production from SigmaTel, >which is usually identified as STAC. chip as "STAC98xx". Additionally, there are no entries for "IDT" anywhere in my Registry. Nor are there any such entries on the Dell driver installation disk. Nor is such a codec driver offered on Dell's Driver Support site for my particular machine. IN fact, I've never seen such drivers offered by Microsoft Update on ANY Dell I've owned, until it was offered after I installed Service Pack 1. How this got offered on Windows Update for my particular audio codec, I will never know. All I do know is that this update is causing many others lots of problems. This is not the first time Windows Update has offered me a "poisonous" unneeded update before. For years, Windows would offer me an HP CD driver (of course, I had no such HP CD/DVD drives). The ONLY time I installed the bugger, I wound up having to reinstall the OS. I assure you, I began looking carefully at such driver updates on Windows Update, and have not repeated my mistake since then. I prefer getting my drivers from my PC manufacturer, anyway. Never had good luck with the drivers offered on Microsoft Update. Donald L McDaniel Please reply to the correct thread and article. ================================================ |
| | #12 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC In article <38o624hdak3rukmms9ec14gsklehp8tvc0@xxxxxx>, orthocross@xxxxxx says... Quote: > On Thu, 8 May 2008 09:01:40 -0500, Andrew Rossmann > <andysnewsreply@xxxxxx_junk.comcast.net> wrote: > Quote: > >In article <kt352418du5dm4fsogqdcdsr4fq7hap8o5@xxxxxx>, > >orthocross@xxxxxx says... Quote: > >> On Wed, 7 May 2008 17:00:04 -0700, jimmy > >> <jimmy@xxxxxx> wrote: > >> > >> >Same thing happened to me. I just went back to the old driver and everything > >> >was fine. Not sure why it did what it did > >> > >> This optional update was also offered to me last week. Knowing my > >> audio is not "IDT", I simply right-clicked on it and put a check-mark > >> beside "Hide". > >In 2006, IDT took over the audio codec chip production from SigmaTel, > >which is usually identified as STAC. > That may be so, but my Dell (bought last month) refers to the Audio > chip as "STAC98xx". Additionally, there are no entries for "IDT" > anywhere in my Registry. Nor are there any such entries on the Dell > driver installation disk. Nor is such a codec driver offered on > Dell's Driver Support site for my particular machine. > > IN fact, I've never seen such drivers offered by Microsoft Update on > ANY Dell I've owned, until it was offered after I installed Service > Pack 1. > > How this got offered on Windows Update for my particular audio codec, > I will never know. All I do know is that this update is causing many > others lots of problems. the version of that file. If it was 6.10.0.5511 or older, it offered the update. Unfortunately, it appears it may also have updated other files that caused compatibility problems. Since this is usually built into a motherboard, there could be minor differences on some. -- If there is a no_junk in my address, please REMOVE it before replying! All junk mail senders will be prosecuted to the fullest extent of the law!! http://home.att.net/~andyross |
| | #13 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC On Fri, 9 May 2008 08:05:39 -0500, Andrew Rossmann <andysnewsreply@xxxxxx_junk.comcast.net> wrote: Quote: >In article <38o624hdak3rukmms9ec14gsklehp8tvc0@xxxxxx>, >orthocross@xxxxxx says... Quote: >> On Thu, 8 May 2008 09:01:40 -0500, Andrew Rossmann >> <andysnewsreply@xxxxxx_junk.comcast.net> wrote: >> Quote: >> >In article <kt352418du5dm4fsogqdcdsr4fq7hap8o5@xxxxxx>, >> >orthocross@xxxxxx says... >> >> On Wed, 7 May 2008 17:00:04 -0700, jimmy >> >> <jimmy@xxxxxx> wrote: >> >> >> >> >Same thing happened to me. I just went back to the old driver and everything >> >> >was fine. Not sure why it did what it did >> >> >> >> This optional update was also offered to me last week. Knowing my >> >> audio is not "IDT", I simply right-clicked on it and put a check-mark >> >> beside "Hide". >> > >> >In 2006, IDT took over the audio codec chip production from SigmaTel, >> >which is usually identified as STAC. >> That may be so, but my Dell (bought last month) refers to the Audio >> chip as "STAC98xx". Additionally, there are no entries for "IDT" >> anywhere in my Registry. Nor are there any such entries on the Dell >> driver installation disk. Nor is such a codec driver offered on >> Dell's Driver Support site for my particular machine. >> >> IN fact, I've never seen such drivers offered by Microsoft Update on >> ANY Dell I've owned, until it was offered after I installed Service >> Pack 1. >> >> How this got offered on Windows Update for my particular audio codec, >> I will never know. All I do know is that this update is causing many >> others lots of problems. >Windows Update was looking for a file named STWRT.SYS. It then looks at >the version of that file. If it was 6.10.0.5511 or older, it offered the >update. Unfortunately, it appears it may also have updated other files >that caused compatibility problems. Since this is usually built into a >motherboard, there could be minor differences on some. fact, all it shows for Audio is the "SigmaTel High Definition Audio Codec." Nor does it show any updates available. My opinion? STAY AWAY from any such "IDT" updates unless you are SURE they are for your machine. And, "If it works already fairly-well, there is no need to update". As they say, "No need to fix what's not broken." Donald L McDaniel Please reply to the correct thread and article. ================================================ |
| | #14 (permalink) |
| Vista Home Premium x32 | Re: IDT - Audio - IDT High Definition Audio CODEC Could anyone please upload the four WRT_M8...INI files from "C:\Program Files\IDT". The reason I am asking for them is that I was affected by the IDT update but dont have the chance to use System Restore. I managed to get sound working again by experimenting, but also accidentally lost my original IDT folder. Thanks in advance |
| Trouble with IDT high definition audio CODEC | Vista General | |||
| SigmaTel High Definition Audio Codec | Vista hardware & devices | |||
| SigmaTel High Definition Audio CODEC | Vista General | |||
| SigmaTel High Definition Audio CODEC | Vista hardware & devices | |||
