| | IDT - Audio - IDT High Definition Audio CODEC After installing this optional Windows VISTA update, I get the error that "No Audio Output Device is Installed". What happened and how do I fix it? -- Alan |
| | Re: IDT - Audio - IDT High Definition Audio CODEC Lost your audio with the Dell IDT codec update? http://msmvps.com/blogs/bradley/arch...ec-update.aspx See the above. MowGreen [MVP 2003-2008] =============== *-343-* FDNY Never Forgotten =============== alanb wrote: Quote: > After installing this optional Windows VISTA update, I get the error that "No > Audio Output Device is Installed". What happened and how do I fix it? > > |
| | Re: IDT - Audio - IDT High Definition Audio CODEC this happened to me i just when to the dell website (my laptop is a dell) and downloaded the 'new' drivers and installed them, after that everything was ok.. i dont know why windows update would install something that would do that... "alanb" <alanb@xxxxxx> wrote in message news:2DBBB761-929D-4EE7-9F44-921F59A6E77C@xxxxxx Quote: > After installing this optional Windows VISTA update, I get the error that > "No > Audio Output Device is Installed". What happened and how do I fix it? > > > -- > Alan |
| | Re: IDT - Audio - IDT High Definition Audio CODEC In article <#6rDiGTrIHA.420@xxxxxx>, android_man@xxxxxx says... Quote: > this happened to me > > i just when to the dell website (my laptop is a dell) and downloaded the > 'new' drivers and installed them, after that everything was ok.. > > i dont know why windows update would install something that would do that... > > > > "alanb" <alanb@xxxxxx> wrote in message > news:2DBBB761-929D-4EE7-9F44-921F59A6E77C@xxxxxx Quote: > > After installing this optional Windows VISTA update, I get the error that > > "No > > Audio Output Device is Installed". What happened and how do I fix it? have an older version of one of the driver files that is not compatible. Unforunately, the one offered by Microsoft is screwing up many computers. If you have a recent Dell desktop, you can try R173209.exe from Dell: http://support.euro.dell.com/support...download.aspx? c=ie&l=en&s=gen&releaseid=R173209&formatcnt=1&libid=0&fileid=235508 Shorter link: http://tinyurl.com/5rpuk5 The web page says it's for an Optilex 740, but internally it says this: Title : Audio:SIGMATEL STAC 92XX C-Major HD Audio Driver Version : A05 OEM Name : SIGMATEL OEM Ver : 6.10.0.5515 Computers : DV061; Dimension - 5100, 5100C, 9100, C521, DC051, DM051, DM061, DV051, Dimension - DXC051, DXC061, DXP051, DXP061, E521; OptiPlex - 210L, 740; Precision - 380, 390, 490, 690; XPS - 420, DXG061, XPS 720, XPS710 Oses : Windows Vista 32-bit Business, Windows Vista 32-bit Home Basic, Windows Vista 32-bit Home Premium, Windows Vista 32-bit Ultimate, Windows Vista 64-bit BusinessWindows Vista 64-bit Home BasicWindows Vista 64-bit Home PremiumWindows Vista 64-bit Ultimate Languages : Brazilian Portuguese, Chinese-S, Chinese-T, English, French, German, Japanese, Korean, Spanish Created : Tue Nov 27 16:41:39 CST 2007 In addition, it works find on my XPS410, which is similar to the Dimension 9200. After updating my audio, I was able to download and install SP1 through Windows Update. My only scare is that after the SP1 update, Windows defaulted to a USB headset instead of my speakers. I had to go into the Sound settings and change the default back. -- If there is a no_junk in my address, please REMOVE it before replying! All junk mail senders will be prosecuted to the fullest extent of the law!! http://home.att.net/~andyross |
| | Re: IDT - Audio - IDT High Definition Audio CODEC I am having this same problem with my gateway after downloading the Vista update. I cant see to fix the problem. I have uninstalled the vista update. My computer installed the software for Sigma Tel High Definition Audio CODEC and said it was "ready to use" but i am still getting the No Audio Output Device installed, and my sound isnt working.... does anyone know how to fix it? I would really really appreciate the help. -- fallingfairies ------------------------------------------------------------------------ fallingfairies's Profile: http://forums.techarena.in/member.php?userid=48201 View this thread: http://forums.techarena.in/showthread.php?t=960985 http://forums.techarena.in |
| | #6 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC fallingfairies <fallingfairies.38wsjf@xxxxxx> wrote: Quote: >I am having this same problem with my gateway after downloading the >Vista update. I cant see to fix the problem. I have uninstalled the >vista update. My computer installed the software for Sigma Tel High >Definition Audio CODEC and said it was "ready to use" but i am still >getting the No Audio Output Device installed, and my sound isnt >working.... does anyone know how to fix it? I would really really >appreciate the help. point. |
| | #7 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC Yes, that's what I did too. I misstated above. "Robert Neville" <dont@xxxxxx> wrote in message news:fvlgps09h5@xxxxxx Quote: > > fallingfairies <fallingfairies.38wsjf@xxxxxx> wrote: > Quote: >>I am having this same problem with my gateway after downloading the >>Vista update. I cant see to fix the problem. I have uninstalled the >>vista update. My computer installed the software for Sigma Tel High >>Definition Audio CODEC and said it was "ready to use" but i am still >>getting the No Audio Output Device installed, and my sound isnt >>working.... does anyone know how to fix it? I would really really >>appreciate the help. > You can't just roll back the driver - you need to go back previous restore > point. |
| | #8 (permalink) |
| | RE: IDT - Audio - IDT High Definition Audio CODEC Same thing happened to me. I just went back to the old driver and everything was fine. Not sure why it did what it did -- jimp "alanb" wrote: Quote: > After installing this optional Windows VISTA update, I get the error that "No > Audio Output Device is Installed". What happened and how do I fix it? > > > -- > Alan |
| | #9 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC On Wed, 7 May 2008 17:00:04 -0700, jimmy <jimmy@xxxxxx> wrote: Quote: >Same thing happened to me. I just went back to the old driver and everything >was fine. Not sure why it did what it did audio is not "IDT", I simply right-clicked on it and put a check-mark beside "Hide". In fact, I feel confident that if I were to unhide this update, it would again be offered to me. My question to those in the Cloud is: "Why is Microsoft offering this optional update to so many who do not need it, or want it?" I also ask any official Microsoft representative to respond, if he reads this post. Of course, I flatter myself to even consider that Microsoft would reply in a Usenet newsgroup to such a person as myself. Donald L McDaniel Please reply to the correct thread and article. ================================================ |
| | #10 (permalink) |
| | Re: IDT - Audio - IDT High Definition Audio CODEC In article <kt352418du5dm4fsogqdcdsr4fq7hap8o5@xxxxxx>, orthocross@xxxxxx says... Quote: > On Wed, 7 May 2008 17:00:04 -0700, jimmy > <jimmy@xxxxxx> wrote: > Quote: > >Same thing happened to me. I just went back to the old driver and everything > >was fine. Not sure why it did what it did > This optional update was also offered to me last week. Knowing my > audio is not "IDT", I simply right-clicked on it and put a check-mark > beside "Hide". which is usually identified as STAC. -- If there is a no_junk in my address, please REMOVE it before replying! All junk mail senders will be prosecuted to the fullest extent of the law!! http://home.att.net/~andyross |
| Trouble with IDT high definition audio CODEC | Vista General | |||
| SigmaTel High Definition Audio Codec | Vista hardware & devices | |||
| SigmaTel High Definition Audio CODEC | Vista General | |||
| SigmaTel High Definition Audio CODEC | Vista hardware & devices | |||
