| Vista Home Premium 32bit. | problem with "d" drive I am using Vista Home Premium @ 32 bits...and a non-tecky, but a frustrated user in-so-far as that my "d" drive is 99% full and I have no way and no know-how to deal with this problem..Any suggestions from some kind soul out there ? The computer flashes that the disk space on RECOVERY "D" is almost full... |
| | Re: problem with "d" drive You have a Dell, I presume. The Recovery D drive is a special drive that Dell has set up on your PC to put your PC back into the 'Factory Delivered' state, making it like the first time you booted it up. 'Recovery' might sound like you should back up files there, but you should not write to that drive at all. Somehow, you are creating files on that drive. If you want to back up files to a drive other than 'C', I suggest an external USB drive - they're pretty cheap and are very good for backup. You can even set up Vista to automatically backup files on a regular schedule. It's on the Dell Welcome screen. UpRider "jkass6" <guest@xxxxxx-email.com> wrote in message news:73825f974af097c877691925cf736d4e@xxxxxx-gateway.com... Quote: > > *I am using Vista Home Premium @ 32 bits...and a non-tecky, but a > frustrated user in-so-far as that my "d" drive is 99% full and I have no > way and no know-how to deal with this problem..Any suggestions from some > kind soul out there ? The computer flashes that the disk space on > RECOVERY "D" is almost full...* > > > -- > jkass6 |
| Vista Home Premium 32bit. | Re: problem with "d" drive Thank you Uprider and if use the external USB drive to put the info from the d drive on it can I then disgorge what is in the D dive so I don't have to look at that reminder that keeps popping up all the time ? |
| | Re: problem with "d" drive "jkass6" <guest@xxxxxx-email.com> wrote in message news:99d89391bfe4d2caa1dd9fc1327ba588@xxxxxx-gateway.com... Quote: > > Thank you Uprider and if use the external USB drive to put the info from > the d drive on it can I then disgorge what is in the D dive so I don't > have to look at that reminder that keeps popping up all the time ? > > > -- > jkass6 You only want to remove files which you have backed up to the drive.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| Moving the Vista equiv. of "My Docs" to "F" drive | Vista file management | |||
| Anno 1404 "save/load" problem and using "runas.exe" | Gaming | |||
| SATA problem? "Please insert disc in drive D:" | General Discussion | |||
| Moving "My DOcuments" and remainder of "My" files to second drive | Vista file management | |||
