| | Mapped network drive issue Hello, If I have a drive mapped to a network share and then run an application 'as administrator' the networked drive is not found. If I use a UNC path rather than the mapped drive letter then the application is able to work correctly. If I run the app using the default credentials then the networked drive is recognised but some apps need to be run 'as administrator' to function correctly. Clearly the problem is that applications running as administrator are not being passed the entire relevant environment from the user account. With the applications I'm currently running I am able to partially overcome some of the problems by typing the complete UNC path rather than merely specifying a drive letter or I can turn off UAC to avoid the need to run as administrator but that's not the case for all apps. Is there a permanent workaround to have mapped network drives recognised for apps which are run 'as administrator' ? I'm using Vista Ultimate, SP1 Ta |
| Mapped Network Drive | Network & Sharing | |||
| Vista SP1 & Mapped drive issue | Vista General | |||
| Cannot open mapped network drive | Vista networking & sharing | |||
| DFS Mapped Drive issue. | Vista networking & sharing | |||
| Network Mapped Drive : Lost Network Connection | Vista networking & sharing | |||
