Vista - USB TO SERIAL 232 NULL CABLE
Old 05-06-2008   #1 (permalink)
irma niurka
I have now vista ,,,but it does not support this sofware ,,,, I was using in
xp, any sugestion?USB TO SERIAL 232 NULL CABLE
Old 05-06-2008   #2 (permalink)
William
Re: USB TO SERIAL 232 NULL CABLE
do you require tel net to use it ?
"irma niurka" <irmanvarona@xxxxxx> wrote in message
news:%23xGMh23rIHA.3616@xxxxxx
>in xp, any sugestion?USB TO SERIAL 232 NULL CABLE
Old 05-06-2008   #3 (permalink)
irma niurka
"William" <wdavidson@xxxxxx> wrote in message
news:6F6237E1-47B7-4C26-A28C-D9675DBAEA96@xxxxxx
> NOP,,,, it not require tel net,,,, MY USB serial cable,,,came with a Cd
> BUT NOT supported x vista ,,,,
Old 05-06-2008   #4 (permalink)
KDE
this says it's vista compatible, I don't know if it will work with your
particular hardware though ?
http://www.virtual-serial-port.com/v...-port-kit.html
news:uDSkch4rIHA.3968@xxxxxx
problem caused usb to serial cable radio shack Vista General
Re: Serial Plonkers v. Serial Killers Vista General
Windows Vista - Need a USB to serial port cable... Vista hardware & devices
Re: "Error: 'null' is null or not an object" when trying to view video Vista performance & maintenance
Gotcha: $null to [string] IS NOT $null PowerShell
