| | Downgrade from Home Premium to Home Basic? I require Dragon NaturallySpeaking voice recognition software to be able to use my computer. I've just purchased an HP laptop preloaded with Vista Home Premium, and have discovered, to my horror, that the current version of DNS will not run on a 64-bit operating system. (The next version might, but there's no guarantee.) The Anytime Upgrade pack looks like an ideal stopgap measure, but will it allow me to downgrade from Premium to Basic? I'm sure that isn't what it's designed to do, but does anybody know (for sure) that it will or won't? Will it then, at some point in the future, upgrade me back to Premium? Thanks in advance! |
| | Re: Downgrade from Home Premium to Home Basic? No, downgrade will not work, it would take a clean install. You should try the Speech Recognition built in to Vista. You will find little D.N.S. could do that S.R. will not. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "Paul" <Paul@xxxxxx> wrote in message news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: > I require Dragon NaturallySpeaking voice recognition software to be able > to > use my computer. I've just purchased an HP laptop preloaded with Vista > Home > Premium, and have discovered, to my horror, that the current version of > DNS > will not run on a 64-bit operating system. (The next version might, but > there's no guarantee.) > > The Anytime Upgrade pack looks like an ideal stopgap measure, but will it > allow me to downgrade from Premium to Basic? I'm sure that isn't what it's > designed to do, but does anybody know (for sure) that it will or won't? > Will > it then, at some point in the future, upgrade me back to Premium? > > Thanks in advance! > > |
| | Re: Downgrade from Home Premium to Home Basic? Contact HP and ask them if your product key will work, and if your recovery disk contains the 32 bit version of Home Premium. you should not have to downgrade to Basic. Home Premium 32 should work. That way you wouldn't loose any functionality. You just need to find out if HP will help you do that. "Paul" <Paul@xxxxxx> wrote in message news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: >I require Dragon NaturallySpeaking voice recognition software to be able to > use my computer. I've just purchased an HP laptop preloaded with Vista > Home > Premium, and have discovered, to my horror, that the current version of > DNS > will not run on a 64-bit operating system. (The next version might, but > there's no guarantee.) > > The Anytime Upgrade pack looks like an ideal stopgap measure, but will it > allow me to downgrade from Premium to Basic? I'm sure that isn't what it's > designed to do, but does anybody know (for sure) that it will or won't? > Will > it then, at some point in the future, upgrade me back to Premium? > > Thanks in advance! > > |
| | Re: Downgrade from Home Premium to Home Basic? Paul the problem is not that you have premium but that your OS is 64 bit But you are entitled to get a DVD with the 32 bit version of home premium with a small cost of shipping and handling, and you will use the same product key that you now have. In other worlds if you have the 32bit you are entitiled to use 64 bit for free and the opposite.. you DON’T have to buy windows all over again! so what you will do is format and install the 32 bit version of your windows after you get the disk. Its better that you ask HP too or look at their site to see if they offer 32 bit versions of your drivers... see this link to find more about vista "alternate" media http://www.microsoft.com/windowsvist...a/default.mspx Perhaps the OEM in your case HP can supply you with the 32 bit version with little or no cost too.. "Paul" <Paul@xxxxxx> wrote in message news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: > I require Dragon NaturallySpeaking voice recognition software to be able > to > use my computer. I've just purchased an HP laptop preloaded with Vista > Home > Premium, and have discovered, to my horror, that the current version of > DNS > will not run on a 64-bit operating system. (The next version might, but > there's no guarantee.) > > The Anytime Upgrade pack looks like an ideal stopgap measure, but will it > allow me to downgrade from Premium to Basic? I'm sure that isn't what it's > designed to do, but does anybody know (for sure) that it will or won't? > Will > it then, at some point in the future, upgrade me back to Premium? > > Thanks in advance! > > |
| | Re: Downgrade from Home Premium to Home Basic? Paul the problem is not that you have premium but that your OS is 64 bit But you are entitled to get a DVD with the 32 bit version of home premium with a small cost of shipping and handling, and you will use the same product key that you now have. In other worlds if you have the 32bit you are entitiled to use 64 bit for free and the opposite.. you DON’T have to buy windows all over again! so what you will do is format and install the 32 bit version of your windows after you get the disk. Its better that you ask HP too or look at their site to see if they offer 32 bit versions of your drivers... here is a link if you got the 32 bit version and looking for the 64 bit one, but I m sure there is a way to do the opposite too http://www.microsoft.com/windowsvist...a/default.mspx Perhaps the OEM in your case HP can supply you with the 32 bit version with little or no cost too.. "Paul" <Paul@xxxxxx> wrote in message news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: > I require Dragon NaturallySpeaking voice recognition software to be able > to > use my computer. I've just purchased an HP laptop preloaded with Vista > Home > Premium, and have discovered, to my horror, that the current version of > DNS > will not run on a 64-bit operating system. (The next version might, but > there's no guarantee.) > > The Anytime Upgrade pack looks like an ideal stopgap measure, but will it > allow me to downgrade from Premium to Basic? I'm sure that isn't what it's > designed to do, but does anybody know (for sure) that it will or won't? > Will > it then, at some point in the future, upgrade me back to Premium? > > Thanks in advance! > > |
| | #6 (permalink) |
| | Re: Downgrade from Home Premium to Home Basic? He is not "entitled" to a 32bit version. Because it's OEM nobody owes him anything. Maybe HP will cooperate, but they are obligated to. He may just have to purchase the 32bit. Mark "Clear Windows" <carlferedeck@xxxxxx> wrote in message news:48209505$1@xxxxxx-privat.org... Quote: > Paul the problem is not that you have premium but that your OS is 64 bit > But you are entitled to get a DVD with the 32 bit version of home premium > with a small cost of shipping and handling, and you will use the same > product key > that you now have. > > In other worlds if you have the 32bit you are entitiled to use 64 bit for > free > and the opposite.. you DON'T have to buy windows all over again! > > so what you will do is format and install the 32 bit version of your > windows > after you get the disk. > > Its better that you ask HP too or look at their site to see if they offer > 32 > bit versions of your drivers... > > see this link to find more about vista "alternate" media > http://www.microsoft.com/windowsvist...a/default.mspx > > Perhaps the OEM in your case HP can supply you with the 32 bit version > with > little or no cost > too.. > > > > > "Paul" <Paul@xxxxxx> wrote in message > news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: >> I require Dragon NaturallySpeaking voice recognition software to be able >> to >> use my computer. I've just purchased an HP laptop preloaded with Vista >> Home >> Premium, and have discovered, to my horror, that the current version of >> DNS >> will not run on a 64-bit operating system. (The next version might, but >> there's no guarantee.) >> >> The Anytime Upgrade pack looks like an ideal stopgap measure, but will it >> allow me to downgrade from Premium to Basic? I'm sure that isn't what >> it's >> designed to do, but does anybody know (for sure) that it will or won't? >> Will >> it then, at some point in the future, upgrade me back to Premium? >> >> Thanks in advance! >> >> |
| | #7 (permalink) |
| | Re: Downgrade from Home Premium to Home Basic? Typo: HP is "not" obligated. "Mark" <secureourborders@xxxxxx> wrote in message news:eiinY$7rIHA.4260@xxxxxx Quote: > He is not "entitled" to a 32bit version. Because it's OEM nobody owes him > anything. Maybe HP will cooperate, but they are obligated to. He may just > have to purchase the 32bit. > > Mark > > "Clear Windows" <carlferedeck@xxxxxx> wrote in message > news:48209505$1@xxxxxx-privat.org... Quote: >> Paul the problem is not that you have premium but that your OS is 64 bit >> But you are entitled to get a DVD with the 32 bit version of home premium >> with a small cost of shipping and handling, and you will use the same >> product key >> that you now have. >> >> In other worlds if you have the 32bit you are entitiled to use 64 bit for >> free >> and the opposite.. you DON'T have to buy windows all over again! >> >> so what you will do is format and install the 32 bit version of your >> windows >> after you get the disk. >> >> Its better that you ask HP too or look at their site to see if they offer >> 32 >> bit versions of your drivers... >> >> see this link to find more about vista "alternate" media >> http://www.microsoft.com/windowsvist...a/default.mspx >> >> Perhaps the OEM in your case HP can supply you with the 32 bit version >> with >> little or no cost >> too.. >> >> >> >> >> "Paul" <Paul@xxxxxx> wrote in message >> news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: >>> I require Dragon NaturallySpeaking voice recognition software to be able >>> to >>> use my computer. I've just purchased an HP laptop preloaded with Vista >>> Home >>> Premium, and have discovered, to my horror, that the current version of >>> DNS >>> will not run on a 64-bit operating system. (The next version might, but >>> there's no guarantee.) >>> >>> The Anytime Upgrade pack looks like an ideal stopgap measure, but will >>> it >>> allow me to downgrade from Premium to Basic? I'm sure that isn't what >>> it's >>> designed to do, but does anybody know (for sure) that it will or won't? >>> Will >>> it then, at some point in the future, upgrade me back to Premium? >>> >>> Thanks in advance! >>> >>> > |
| | #8 (permalink) |
| | Re: Downgrade from Home Premium to Home Basic? The OEM is not forced to give him a 32 bit DVD, BUT his product key will probably work nevertheless. All he has to do is obtain an OEM version of 32 bit vista home premium and make sure HP has the drivers for his model of laptop in 32 bit versions. MS has stated clearly, when you get one version of vista (32 or 64 bit) you actually own both versions, and can install either one without the need to purchase another version from scratch. "Mark" <secureourborders@xxxxxx> wrote in message news:eiinY$7rIHA.4260@xxxxxx Quote: > He is not "entitled" to a 32bit version. Because it's OEM nobody owes him > anything. Maybe HP will cooperate, but they are obligated to. He may just > have to purchase the 32bit. > > Mark > > "Clear Windows" <carlferedeck@xxxxxx> wrote in message > news:48209505$1@xxxxxx-privat.org... Quote: >> Paul the problem is not that you have premium but that your OS is 64 bit >> But you are entitled to get a DVD with the 32 bit version of home premium >> with a small cost of shipping and handling, and you will use the same >> product key >> that you now have. >> >> In other worlds if you have the 32bit you are entitiled to use 64 bit for >> free >> and the opposite.. you DON'T have to buy windows all over again! >> >> so what you will do is format and install the 32 bit version of your >> windows >> after you get the disk. >> >> Its better that you ask HP too or look at their site to see if they offer >> 32 >> bit versions of your drivers... >> >> see this link to find more about vista "alternate" media >> http://www.microsoft.com/windowsvist...a/default.mspx >> >> Perhaps the OEM in your case HP can supply you with the 32 bit version >> with >> little or no cost >> too.. >> >> >> >> >> "Paul" <Paul@xxxxxx> wrote in message >> news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx Quote: >>> I require Dragon NaturallySpeaking voice recognition software to be able >>> to >>> use my computer. I've just purchased an HP laptop preloaded with Vista >>> Home >>> Premium, and have discovered, to my horror, that the current version of >>> DNS >>> will not run on a 64-bit operating system. (The next version might, but >>> there's no guarantee.) >>> >>> The Anytime Upgrade pack looks like an ideal stopgap measure, but will >>> it >>> allow me to downgrade from Premium to Basic? I'm sure that isn't what >>> it's >>> designed to do, but does anybody know (for sure) that it will or won't? >>> Will >>> it then, at some point in the future, upgrade me back to Premium? >>> >>> Thanks in advance! >>> >>> > |
| | #9 (permalink) |
| | Re: Downgrade from Home Premium to Home Basic? to clarify, when I say "All he has to do is obtain an OEM version of 32 bit vista home premium" I do NOT mean buying vista from the start again, only the dvd disk as a media replacement there are many ways to get this... even if his OEM doesn't want to give a disk to him. "Clear Windows" <carlferedeck@xxxxxx> wrote in message news:4820d2b4$1@xxxxxx-privat.org... Quote: > The OEM is not forced to give him a 32 bit DVD, BUT > > his product key will probably work nevertheless. > > All he has to do is obtain an OEM version of 32 bit vista home premium and > make sure HP has the drivers for his model of > laptop in 32 bit versions. > > MS has stated clearly, when you get one version of vista (32 or 64 bit) > you actually own both versions, and can install either one without the > need to purchase another version from scratch. > > > > > > "Mark" <secureourborders@xxxxxx> wrote in message > news:eiinY$7rIHA.4260@xxxxxx Quote: >> He is not "entitled" to a 32bit version. Because it's OEM nobody owes him >> anything. Maybe HP will cooperate, but they are obligated to. He may just >> have to purchase the 32bit. >> >> Mark >> >> "Clear Windows" <carlferedeck@xxxxxx> wrote in message >> news:48209505$1@xxxxxx-privat.org... Quote: >>> Paul the problem is not that you have premium but that your OS is 64 bit >>> But you are entitled to get a DVD with the 32 bit version of home >>> premium >>> with a small cost of shipping and handling, and you will use the same >>> product key >>> that you now have. >>> >>> In other worlds if you have the 32bit you are entitiled to use 64 bit >>> for free >>> and the opposite.. you DON'T have to buy windows all over again! >>> >>> so what you will do is format and install the 32 bit version of your >>> windows >>> after you get the disk. >>> >>> Its better that you ask HP too or look at their site to see if they >>> offer 32 >>> bit versions of your drivers... >>> >>> see this link to find more about vista "alternate" media >>> http://www.microsoft.com/windowsvist...a/default.mspx >>> >>> Perhaps the OEM in your case HP can supply you with the 32 bit version >>> with >>> little or no cost >>> too.. >>> >>> >>> >>> >>> "Paul" <Paul@xxxxxx> wrote in message >>> news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx >>>> I require Dragon NaturallySpeaking voice recognition software to be >>>> able >>>> to >>>> use my computer. I've just purchased an HP laptop preloaded with Vista >>>> Home >>>> Premium, and have discovered, to my horror, that the current version of >>>> DNS >>>> will not run on a 64-bit operating system. (The next version might, >>>> but >>>> there's no guarantee.) >>>> >>>> The Anytime Upgrade pack looks like an ideal stopgap measure, but will >>>> it >>>> allow me to downgrade from Premium to Basic? I'm sure that isn't what >>>> it's >>>> designed to do, but does anybody know (for sure) that it will or won't? >>>> Will >>>> it then, at some point in the future, upgrade me back to Premium? >>>> >>>> Thanks in advance! >>>> >>>> >> |
| | #10 (permalink) |
| | Re: Downgrade from Home Premium to Home Basic? If HP does not cooperate he will need to purchase at least an OEM version of Vista 32bit. Microsoft will not give it to him. Mark "Clear Windows" <carlferedeck@xxxxxx> wrote in message news:4820d2b4$1@xxxxxx-privat.org... Quote: > The OEM is not forced to give him a 32 bit DVD, BUT > > his product key will probably work nevertheless. > > All he has to do is obtain an OEM version of 32 bit vista home premium and > make sure HP has the drivers for his model of > laptop in 32 bit versions. > > MS has stated clearly, when you get one version of vista (32 or 64 bit) > you actually own both versions, and can install either one without the > need to purchase another version from scratch. > > > > > > "Mark" <secureourborders@xxxxxx> wrote in message > news:eiinY$7rIHA.4260@xxxxxx Quote: >> He is not "entitled" to a 32bit version. Because it's OEM nobody owes him >> anything. Maybe HP will cooperate, but they are obligated to. He may just >> have to purchase the 32bit. >> >> Mark >> >> "Clear Windows" <carlferedeck@xxxxxx> wrote in message >> news:48209505$1@xxxxxx-privat.org... Quote: >>> Paul the problem is not that you have premium but that your OS is 64 bit >>> But you are entitled to get a DVD with the 32 bit version of home >>> premium >>> with a small cost of shipping and handling, and you will use the same >>> product key >>> that you now have. >>> >>> In other worlds if you have the 32bit you are entitiled to use 64 bit >>> for free >>> and the opposite.. you DON'T have to buy windows all over again! >>> >>> so what you will do is format and install the 32 bit version of your >>> windows >>> after you get the disk. >>> >>> Its better that you ask HP too or look at their site to see if they >>> offer 32 >>> bit versions of your drivers... >>> >>> see this link to find more about vista "alternate" media >>> http://www.microsoft.com/windowsvist...a/default.mspx >>> >>> Perhaps the OEM in your case HP can supply you with the 32 bit version >>> with >>> little or no cost >>> too.. >>> >>> >>> >>> >>> "Paul" <Paul@xxxxxx> wrote in message >>> news:E3541017-6F63-4335-95BF-A4B6E79E7AA8@xxxxxx >>>> I require Dragon NaturallySpeaking voice recognition software to be >>>> able >>>> to >>>> use my computer. I've just purchased an HP laptop preloaded with Vista >>>> Home >>>> Premium, and have discovered, to my horror, that the current version of >>>> DNS >>>> will not run on a 64-bit operating system. (The next version might, >>>> but >>>> there's no guarantee.) >>>> >>>> The Anytime Upgrade pack looks like an ideal stopgap measure, but will >>>> it >>>> allow me to downgrade from Premium to Basic? I'm sure that isn't what >>>> it's >>>> designed to do, but does anybody know (for sure) that it will or won't? >>>> Will >>>> it then, at some point in the future, upgrade me back to Premium? >>>> >>>> Thanks in advance! >>>> >>>> >> |
| Windows Vista Home Premium Key Home Basic Discs | General Discussion | |||
| ip4200: Vista Home Basic Fails, but Home premium works | Vista print fax & scan | |||
| Re: Anytime Upgrade from Vista Home Basic to Home Premium | Vista installation & setup | |||
| Downgrade from Vista Home Premium to Home Basic | Vista General | |||
| Downgrade Vista Home Premium to XP Home | Vista installation & setup | |||
