| | remember folder ANNOYING PROBLEM I know every one here has this default Vista (even XP) problem. The problem is that the folder customization / layout never stays the way you set it, even minutes later after closing/re-opening explorer. This is driving me insane. For example, in explorer under Computer I choose large icons. Close, re-open its back to list view instead. Sometimes other folders will somehow change views by themselves too. This is really annoying. Someone suggested a fix months ago, but I do not remember how. Would appreciate tips on this. I *do* already have checked on "remember folder's view settings" enabled as well. Running: Vista Ultimate 64bit w/ SP1 I tried this method, made it even worst: http://thevistaforums.com/index.php?showtopic=23106 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: remember folder ANNOYING PROBLEM I know every one here has this default Vista (even XP) problem. The problem is that the folder customization / layout never stays the way you set it, even minutes later after closing/re-opening explorer. This is driving me insane. For example, in explorer under Computer I choose large icons. Close, re-open its back to list view instead. Sometimes other folders will somehow change views by themselves too. This is really annoying. Someone suggested a fix months ago, but I do not remember how. Would appreciate tips on this. I *do* already have checked on "remember folder's view settings" enabled as well. Running: Vista Ultimate 64bit w/ SP1 I tried this method, made it even worst: Remember Folder Settings (FINALLY Works!) - Windows Vista Forums Try Method Two in this tutorial. It will help Vista remember your folder view settings for a window for when it was last closed. Windows Explorer Folder View settings Hope this helps, Shawn |
| | Re: remember folder ANNOYING PROBLEM Wrongo bubba, this is a common oft cited Vista bug. On Tue, 6 May 2008 14:10:01 -0700, Mick Murphy <MickMurphy@xxxxxx> wrote: Quote: >You are the annoying problem here! |
| remember folder ANNOYING PROBLEM | Vista General | |||
| IE doesn't remember the last download folder | Vista General | |||
| Vista Won't Remember Folder Views | Vista General | |||
