Vista Tutorial - remember folder ANNOYING PROBLEM
Old 05-06-2008   #1 (permalink)
Chad
Guest
I know every one here has this default Vista (even XP) problem. The problem
is that the folder customization / layout never stays the way you set it,
even minutes later after closing/re-opening explorer.
This is driving me insane. For example, in explorer under Computer I choose
large icons. Close, re-open its back to list view instead. Sometimes other
folders will somehow change views by themselves too. This is really annoying.
Someone suggested a fix months ago, but I do not remember how. Would
appreciate tips on this. I *do* already have checked on "remember folder's
view settings" enabled as well.
Running:
Vista Ultimate 64bit w/ SP1
I tried this method, made it even worst:
http://thevistaforums.com/index.php?showtopic=23106
Old 05-06-2008   #2 (permalink)
Administrator
Re: remember folder ANNOYING PROBLEM
Quote  Quote: Originally Posted by Chad View Post
Running:
Remember Folder Settings (FINALLY Works!) - Windows Vista Forums
Hi Chad,
Try Method Two in this tutorial. It will help Vista remember your folder view settings for a window for when it was last closed.
Windows Explorer Folder View settings
Old 05-06-2008   #3 (permalink)
Chad
Guest
RE: remember folder ANNOYING PROBLEM
Relax MS fanboy, don't pop a vessel in your head.
Search Vista forums and you'll see many had the same issue. XP and Vista are
two different OS Einstein.
remember folder ANNOYING PROBLEM Vista General
IE doesn't remember the last download folder Vista General
Vista Won't Remember Folder Views Vista General
