Vista - problem with donwloading zip files
Old 05-06-2008   #1 (permalink)
Paul (Bornival)
When I try to dowload a zip file from the web with my VISTA computer, I get
an empty file (0 KB) ... If I do the same with my WinXP computer, I get the
file correctly... I tried this
- with Internet Explorer and FireFox with the same results
- after having unloaded ZoneAlarm
but to no avail...
What is blocking VISTA when trying ot download a zip file ?
Old 05-06-2008   #2 (permalink)
Mark L. Ferguson
Re: problem with donwloading zip files
I would try re-registering the zip activeX component.
Rightclick the Command Prompt icon on the start menu, and click 'run as
administrator'
Run the command:
regsvr32 zipfldr.dll
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Paul (Bornival)" <PaulBornival@xxxxxx> wrote in message
news:2DFE9DC2-8020-433E-A7CD-B00D2861F21F@xxxxxx
Quote:
> Hi,
> get
> the
> but to no avail...
Old 05-06-2008   #3 (permalink)
Clear Windows
install a download manager like www.freedownloadmanager.org
free
Quote:
> Hi,
> get
> the
> but to no avail...
Old 05-07-2008   #4 (permalink)
Paul (Bornival)
Thank you. I'll try tomorrow since the probelm is on my portable computer
which I lefy at work.
Paul.
> administrator'
> Run the command:
> interface.
> Mark L. Ferguson
Quote:
> > Hi,
> > get
> > the
> > but to no avail...
Old 05-08-2008   #5 (permalink)
Paul (Bornival)
I eventually came across the same problem from a WinXP machine this time...
I tried what you suggested with this WinXP machine but it did not help. I'll
try tonight with my VISTA machine. However, I now wonder if this is not due
to firewall configuration. Both machines run ZoneAlarm, but with different
versions since ZA for XP is difefrent from that for VISTA. However, the
first XP machine I used did notr have this problem (which is why I tought is
was due to VISTA) and it runs also ZoneAlarm. I'll stry to see with other
machines ...
What is even more puzzling is that the problem is not for all zip files,
since I 'am able to dwonload other ones from other web sites. I'll further
explore this...
But, in tne meantime, do you have another clue or suggestions ?
> administrator'
> Run the command:
> interface.
> Mark L. Ferguson
Quote:
> > Hi,
> > get
> > the
> > but to no avail...
Old 05-08-2008   #6 (permalink)
Mark L. Ferguson
I would suspect %TEMP% folder corruption. Click Start, and type : %TEMP% and
hit [ENTER]
Clear the folder and restart.
interface.
Mark L. Ferguson
news:978C012F-2C2A-4094-AC40-D91CC26D1E01@xxxxxx
Quote:
> Hi,
> time...
> I'll
> due
> different
> is
> machines ...
> further
> explore this...
>> administrator'
>> Run the command:
>> interface.
>> Mark L. Ferguson
>> message
Quote:
>> > Hi,
>> > get
>> > the
>> > but to no avail...
Old 06-05-2008   #7 (permalink)
Paul (Bornival)
Thank you for your sggestion.
Actually, I found out that the problem was with the web site it-self. Some
programming error made that when requesting a spcific zip file, the server
failed to make the file and sent only a empty file.
Anyway, thanks for your help.
Paul.
> hit [ENTER]
> interface.
> Mark L. Ferguson
Quote:
> > Hi,
> > time...
> > I'll
> > due
> > different
> > is
> > machines ...
> > further
> > explore this...
> >> administrator'
> >> Run the command:
> >> interface.
> >> Mark L. Ferguson
> >> message
> >> > Hi,
> >> > get
> >> > the
> >> > but to no avail...
OT: Problem with PDF files Vista General
Still have a problem with asx/asf files Vista General
problem with RAR files Vista General
Problem with txt files Vista General
Odd problem with .ini files Vista General
