Vista - Dual monitor display settings revert on startup
Old 05-07-2008   #1 (permalink)
Cal
I run Vista on a laptop and have a 2nd monitor hooked up via a docking station.
I set my 2nd monitor (i.e. not the laptop screen) as my main monitor,
however, after every restart Vista always reverts back to the Laptop as the
main monitor.
How can I stop Vista reverting backto the Laptop as the main monitor?
(This happens aven though at no stage have I un-docked the laptop!)
Old 05-07-2008   #2 (permalink)
Synapse Syndrome
Re: Dual monitor display settings revert on startup
"Cal" <Cal@xxxxxx> wrote in message
news:41E5F080-20F0-411F-835D-D8178036DD34@xxxxxx
>station.
> the
> main monitor.
This happens with my twin monitors, and somebody else here mentioned the
same thing when using a laptop just a couple of days ago. It seems to be a
common problem with Vista, but I have never seen it happen in XP.
If you had twin monitors you could swap the cables around every time it
happens, but as you are using a laptop, using UltraMon will be the only
solution that I can think of. It allows you to change the primary monitor
very easily.
www.ultramon.com
ss.
Old 05-07-2008   #3 (permalink)
Malcz86
We've had this problem quite a lot on XP and it was todo with a graphics
chipset control panel option which overwrites the windows settings after a
reboot. If you want the change to be permanent you need to setup the dual
monitor in the chipset control panel.
Not sure if its the same as this was XP but sounds a lot like it.
> >station.
> > the
> > main monitor.
> very easily.
> www.ultramon.com
> ss.
Old 05-07-2008   #4 (permalink)
Synapse Syndrome
"Malcz86" <Malcz86@xxxxxx> wrote in message
news:9E884A68-EBBD-4ED1-A453-2E5D7487B55F@xxxxxx
I have used many dual-head XP systems over the years, but have never seen it
happen, with Matrox, ATi and nVidia GPUs. I have seen it happen on the only
two Vista dual-head systems that I have used, including my own. It does not
happen on that same computer when booted into XP. I also cannot remember
there ever being a way to choose which monitor is primary either (ATi FireGL
and nVidia QuadroFX) on the Vista drivers.
ss.
Old 05-07-2008   #5 (permalink)
Bogey Man
> station.
> the
> main monitor.
The software for my video card has a box to "automatically detect monitor"
and another one "manually select monitor". Now this is on a desktop computer
but on the off chance that your video card has the same choice it might be
worth taking a look for.
Ron P
If we are what we eat then: I'm fast,
cheap and easy and past my best before date
Old 05-07-2008   #6 (permalink)
Cal
Thanks Ron! I'll give it a shot.
> > station.
> > the
> > main monitor.
> Ron P
Old 06-25-2008   #7 (permalink)
peter22
Hello,
Also experienced loosing the dual display monitor settings after
reboot/sleep/hybernate/Lock using Vista an a Dell Inspiron 6000 note
book.
Finally fixed this issue installing the latest ATI drivers after using
a special tool: Mobility Modder. Please have a look at:
http://www.driverheaven.net/modtool.php
Peter.
peter22
peter22's Profile: http://forums.techarena.in/member.php?u=52030
View this thread: http://forums.techarena.in/showthread.php?t=963300
Vista logon changes Dual monitor display settings Vista General
Loosing Display Settings On Monitor Vista hardware & devices
Dual Monitor Display Vista General
Monitor/Display Problems at Startup Vista hardware & devices
which monitor to use under display settings? Vista General
