Vista - Task Scheduler Problem
Old 05-07-2008   #1 (permalink)
Keith
I have a vbs script that I use to copy files from my local drive to a network
drive as a backup. The script works fine on its own (by double-clicking it
or by running it from the command prompt). I created a scheduled task to
have it run automatically, but it doesn't seem to work. It says that it
completed successfully, but it didn't really do anything. Even if I select
it in the Task Scheduler and then click "Run" in the Actions pane, it says
it's status is "Running", but nothing is happening. What am I doing wrong?
Thanks,
Keith
Old 05-07-2008   #2 (permalink)
Mark L. Ferguson
Re: Task Scheduler Problem
Create a script or bat file that runs the command:
runas /user:<yourUserName> "cscript \"yourScript.VBS\" "
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Keith" <Keith@xxxxxx> wrote in message
news:6C1064A5-5A80-4970-A1DB-58C0A05A8415@xxxxxx
> network
> it
> select
> wrong?
> Thanks,
> Keith
Old 05-07-2008   #3 (permalink)
Keith
Mark,
Thanks for the response. I tried creating a script which calls my script as
you suggested, and then created a scheduled task to run that new script, but
I got the same result. Do you have any other suggestions?
Thanks,
Keith
> interface.
> Mark L. Ferguson
> > network
> > it
> > select
> > wrong?
> > Thanks,
> > Keith
Old 05-07-2008   #4 (permalink)
Mark L. Ferguson
It's very likely that the script won't run because it's calling something
that needs you to 'run as administrator'. There are several ways you might
accomplish this, but I'm not sure which one would work from Scheduled Tasks.
One direct method might be to enable the default admin, and 'runas' that
user.
Go to Start/all programs/accessories/run, and type:
control userpasswords2
Advanced tab, Advanced button, Users folder, rightclick Administrator,
Properties, uncheck checkbox for "Account is disabled"
Restart Windows.
There could be other methods, but 'runas /user:Administrator ...' would be
tested this way and you could look for other ways to accomplish this.
interface.
Mark L. Ferguson
news:747F1A15-4206-466E-9679-AA6060305894@xxxxxx
Quote:
> Mark,
> as
> but
> Thanks,
> Keith
>> interface.
>> Mark L. Ferguson
>> > network
>> > double-clicking
>> > it
>> > to
>> > it
>> > select
>> > says
>> > wrong?
>> > Thanks,
>> > Keith
Old 05-07-2008   #5 (permalink)
Keith
Mark,
Thanks again for your input. I enabled the default Administrator as you
suggested, but I'm not sure what that will do. I have another vbs script
that also doesn't work properly. All it's supposed to do is pop up a msgbox
reminding me to do something. What's weird is that the backup one I
originally posted about says that it completed successfully, even though it
didn't do anything. I never receive any error message, it just doesn't do
what it's supposed to.
Following is the script for the backup, just in case that helps:
Dim PathVar
Dim RefNo
Dim objFSO
Dim objShell
Dim ShellString
Dim retvalue
Dim VarFilename
set objShell = Wscript.CreateObject("Wscript.Shell")
VarFilename= "xcopy " & chr(34) & "C:\Users\kgrabske\Documents\*.*" &
chr(34) & chr(32) & chr(34) & "Z:\backup\Keith\Documents\*.*" & chr(34)
VarFilename=VarFilename & " /e /y /c /h /d
/EXCLUDE:C:\Users\kgrabske\Documents\BackupExclusions.txt"
objShell.run VarFilename
There isn't much to it, and I can't figure out why special permissions would
be required. I am already running the task using my login, and I am an
administrator.
Do you have any other thoughts? I may see if Macro Scheduler will work. I
used to use that a lot, but I moved away from it in favor of XP's scheduled
tasks, which see to work much better than Vista's.
Thanks,
Keith
> user.
> Restart Windows.
> interface.
> Mark L. Ferguson
Quote:
> > Mark,
> > as
> > but
> > Thanks,
> > Keith
> >> interface.
> >> Mark L. Ferguson
> >> > network
> >> > double-clicking
> >> > it
> >> > to
> >> > it
> >> > select
> >> > says
> >> > wrong?
> >> > Thanks,
> >> > Keith
Old 05-07-2008   #6 (permalink)
Mark L. Ferguson
I would log on as default "Administrator" and schedule the task., or at
least test the run.
If it's a permissions error, that should solve it.
interface.
Mark L. Ferguson
news:6F83A395-D52F-4458-A692-6DCFA611F76C@xxxxxx
Quote:
> Mark,
> msgbox
> it
> Dim PathVar
> Dim RefNo
> Dim objFSO
> Dim objShell
> Dim ShellString
> Dim retvalue
> Dim VarFilename
> would
> administrator.
> I
> scheduled
> Thanks,
> Keith
>> might
>> Tasks.
>> user.
>> Restart Windows.
>> be
>> interface.
>> Mark L. Ferguson
Quote:
>> > Mark,
>> > script
>> > as
>> > script,
>> > but
>> > Thanks,
>> > Keith
>> >> interface.
>> >> Mark L. Ferguson
>> >> > a
>> >> > network
>> >> > double-clicking
>> >> > it
>> >> > task
>> >> > to
>> >> > that
>> >> > it
>> >> > select
>> >> > it
>> >> > says
>> >> > wrong?
>> >> > Thanks,
>> >> > Keith
Old 05-08-2008   #7 (permalink)
Keith
Mark,
I tried logging on as administrator, and my scheduled task did the same
thing. Then I created a new scheduled task while still logged on as
administrator, and I got the same results...task completed when nothing
actually happened. Unless I can come up with a solution to this problem
soon, I will have to investigate alternatives like Macro Scheduler. I
suppose there's no guarantee that it will work any better, but I've got to do
something.
Thanks again for all of your help. I really appreciate it, even if we
haven't yet come up with a solution.
Sincerely,
Keith
> least test the run.
> interface.
> Mark L. Ferguson
Quote:
> > Mark,
> > msgbox
> > it
> > Dim PathVar
> > Dim RefNo
> > Dim objFSO
> > Dim objShell
> > Dim ShellString
> > Dim retvalue
> > Dim VarFilename
> > would
> > administrator.
> > I
> > scheduled
> > Thanks,
> > Keith
> >> might
> >> Tasks.
> >> user.
> >> Restart Windows.
> >> be
> >> interface.
> >> Mark L. Ferguson
> >> > Mark,
> >> > script
> >> > as
> >> > script,
> >> > but
> >> > Thanks,
> >> > Keith
> >> >> interface.
> >> >> Mark L. Ferguson
> >> >> > a
> >> >> > network
> >> >> > double-clicking
> >> >> > it
> >> >> > task
> >> >> > to
> >> >> > that
> >> >> > it
> >> >> > select
> >> >> > it
> >> >> > says
> >> >> > wrong?
> >> >> > Thanks,
> >> >> > Keith
Old 05-08-2008   #8 (permalink)
Mark L. Ferguson
It's acting like you get 'access denied' on the xcopy, but that other
script's failure on simply running a popup dialog indicates something
deeper. You don't get the wscript object at all. I would say that indicates
a Policy setting against script, except that you can run a script in other
than Scheduled Tasks.
Let's write a vbs that runs in CScript, with some echos, to get a console
window.
command: cscript go.vbs
--go.vbs--
wscript.sleep 1000
wscript.echo "Echo works"
wscript.sleep 1000
shell=createobject("wscript.shell")
if shell is nothing then
wscript.echo "No Shell"
end if
wscript.sleep 3000
wscript.exit
--end file-
interface.
Mark L. Ferguson
news:4AFCE5F0-DE85-4FC3-A5BA-B39EC4DC1BA3@xxxxxx
Quote:
> Mark,
> do
> something.
> Sincerely,
> Keith
>> least test the run.
>> interface.
>> Mark L. Ferguson
Quote:
>> > Mark,
>> > you
>> > script
>> > msgbox
>> > though
>> > it
>> > do
>> > Dim PathVar
>> > Dim RefNo
>> > Dim objFSO
>> > Dim objShell
>> > Dim ShellString
>> > Dim retvalue
>> > Dim VarFilename
>> > would
>> > administrator.
>> > work.
>> > I
>> > scheduled
>> > Thanks,
>> > Keith
>> >> something
>> >> might
>> >> Tasks.
>> >> that
>> >> user.
>> >> Restart Windows.
>> >> would
>> >> be
>> >> interface.
>> >> Mark L. Ferguson
>> >> > Mark,
>> >> > script
>> >> > as
>> >> > script,
>> >> > but
>> >> > Thanks,
>> >> > Keith
>> >> >> web
>> >> >> interface.
>> >> >> Mark L. Ferguson
>> >> >> > to
>> >> >> > a
>> >> >> > network
>> >> >> > double-clicking
>> >> >> > it
>> >> >> > task
>> >> >> > to
>> >> >> > that
>> >> >> > it
>> >> >> > if I
>> >> >> > select
>> >> >> > pane,
>> >> >> > it
>> >> >> > says
>> >> >> > doing
>> >> >> > wrong?
>> >> >> > Thanks,
>> >> >> > Keith
Old 05-08-2008   #9 (permalink)
Keith
Mark,
I copied and pasted the code you supplied into a text file an then tried to
run the script from the command line. Following are the results:
C:\Documents and Settings\kgrabske\Documents\AAScripts>cscript go.vbs
Microsoft (R) Windows Script Host Version 5.7
Copyright (C) Microsoft Corporation. All rights reserved.
Echo works
C:\Documents and Settings\kgrabske\Documents\AAScripts\go.vbs(5, 1)
Microsoft VB
Script runtime error: Object doesn't support this property or method: 'shell'
I'm not really an expert on scripting, but it looks like the problem is on
the following line:
Am I right in assuming that we need to get the script working from the
command line before we can use it to test the Task Scheduler?
Thanks,
Keith
> window.
> --go.vbs--
> wscript.sleep 1000
> wscript.sleep 1000
> end if
> wscript.sleep 3000
> wscript.exit
> --end file-
> interface.
> Mark L. Ferguson
Quote:
> > Mark,
> > do
> > something.
> > Sincerely,
> > Keith
> >> least test the run.
> >> interface.
> >> Mark L. Ferguson
> >> > Mark,
> >> > you
> >> > script
> >> > msgbox
> >> > though
> >> > it
> >> > do
> >> > Dim PathVar
> >> > Dim RefNo
> >> > Dim objFSO
> >> > Dim objShell
> >> > Dim ShellString
> >> > Dim retvalue
> >> > Dim VarFilename
> >> > would
> >> > administrator.
> >> > work.
> >> > I
> >> > scheduled
> >> > Thanks,
> >> > Keith
> >> >> something
> >> >> might
> >> >> Tasks.
> >> >> that
> >> >> user.
> >> >> Restart Windows.
> >> >> would
> >> >> be
> >> >> interface.
> >> >> Mark L. Ferguson
> >> >> > Mark,
> >> >> > script
> >> >> > as
> >> >> > script,
> >> >> > but
> >> >> > Thanks,
> >> >> > Keith
> >> >> >> web
> >> >> >> interface.
> >> >> >> Mark L. Ferguson
> >> >> >> > to
> >> >> >> > a
> >> >> >> > network
> >> >> >> > double-clicking
> >> >> >> > it
> >> >> >> > task
> >> >> >> > to
> >> >> >> > that
> >> >> >> > it
> >> >> >> > if I
> >> >> >> > select
> >> >> >> > pane,
> >> >> >> > it
> >> >> >> > says
> >> >> >> > doing
> >> >> >> > wrong?
> >> >> >> > Thanks,
> >> >> >> > Keith
Old 05-08-2008   #10 (permalink)
Mark L. Ferguson
yes, I missed the 'set' command.
set shell=create...
interface.
Mark L. Ferguson
news:AA069875-90ED-4068-97A6-24F5D817F39F@xxxxxx
Quote:
> Mark,
> to
> Echo works
> Microsoft VB
> 'shell'
> the following line:
> Thanks,
> Keith
>> indicates
>> other
>> window.
>> --go.vbs--
>> wscript.sleep 1000
>> wscript.sleep 1000
>> end if
>> wscript.sleep 3000
>> wscript.exit
>> --end file-
>> interface.
>> Mark L. Ferguson
Quote:
>> > Mark,
>> > problem
>> > to
>> > do
>> > something.
>> > Sincerely,
>> > Keith
>> >> at
>> >> least test the run.
>> >> interface.
>> >> Mark L. Ferguson
>> >> > Mark,
>> >> > you
>> >> > script
>> >> > a
>> >> > msgbox
>> >> > though
>> >> > it
>> >> > doesn't
>> >> > do
>> >> > Dim PathVar
>> >> > Dim RefNo
>> >> > Dim objFSO
>> >> > Dim objShell
>> >> > Dim ShellString
>> >> > Dim retvalue
>> >> > Dim VarFilename
>> >> > chr(34)
>> >> > permissions
>> >> > would
>> >> > an
>> >> > administrator.
>> >> > work.
>> >> > I
>> >> > scheduled
>> >> > Thanks,
>> >> > Keith
>> >> >> something
>> >> >> you
>> >> >> might
>> >> >> Scheduled
>> >> >> Tasks.
>> >> >> that
>> >> >> user.
>> >> >> Administrator,
>> >> >> Restart Windows.
>> >> >> would
>> >> >> be
>> >> >> this.
>> >> >> web
>> >> >> interface.
>> >> >> Mark L. Ferguson
>> >> >> > Mark,
>> >> >> > my
>> >> >> > script
>> >> >> > as
>> >> >> > script,
>> >> >> > but
>> >> >> > Thanks,
>> >> >> > Keith
>> >> >> >> the
>> >> >> >> web
>> >> >> >> interface.
>> >> >> >> Mark L. Ferguson
>> >> >> >> > drive
>> >> >> >> > to
>> >> >> >> > a
>> >> >> >> > network
>> >> >> >> > double-clicking
>> >> >> >> > it
>> >> >> >> > scheduled
>> >> >> >> > task
>> >> >> >> > to
>> >> >> >> > says
>> >> >> >> > that
>> >> >> >> > it
>> >> >> >> > Even
>> >> >> >> > if I
>> >> >> >> > select
>> >> >> >> > pane,
>> >> >> >> > it
>> >> >> >> > says
>> >> >> >> > doing
>> >> >> >> > wrong?
>> >> >> >> > Thanks,
>> >> >> >> > Keith
Task Scheduler Problem Vista General
Task Scheduler Problem General Discussion
Task scheduler problem Vista General
Task scheduler problem : task do not close Vista General
