Vista - Problem viewing folders
Old 05-09-2008   #1 (permalink)
D R Jenkins
I tried to change the display settings in my 'preferences' or 'personalise'
folder, clicking on a bigger resolution made the display too big for my
screen but then reverted back because i could not confirm it. Since then any
folder windows I open appear off screen. The start bar and programs such as
internet explorer open fine on screen and maximise as normal, but all folder
windows, recycle bin, control panel etc appear to open off screen. I've
changed my start bar settings so i can access control panel by expanding
folders in the classic way but i still cannot access my 'personalise' folder.
i cannot thing of any other way to get it back to normal and I've only been
using Vista for an hour.
Thanks.
Old 05-09-2008   #2 (permalink)
Re: Problem viewing folders
Quote  Quote: Originally Posted by D R Jenkins View Post
Thanks.
Hi D R Jenkins,
You might try booting into Safe Mode and change the display settings back there. This way you will be able to have everything onscreen to see what you are doing. This tutorial will show you how to boot into Safe Mode if needed.
SAFE MODE:
Safe Mode
SCREEN RESOLUTION:
You might also check to make sure that you DPI settings are not above the default 96 DPI. This can cause everything to appear large and offscreen as well. Here's a tutorial on it to.
DPI Scaling
Hope this helps you,
Old 05-09-2008   #3 (permalink)
Rick Rogers
System Restore, go back to a time that predates your change.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"D R Jenkins" <DRJenkins@xxxxxx> wrote in message
news:8619A907-FB4A-4EEA-98F7-B14005F9D2A7@xxxxxx
> any
> as
> folder
> folder.
> been
> Thanks.
Viewing folders while viewing in-box Vista mail
Problem viewing folders Vista installation & setup
Viewing Hidden files and folders Vista file management
Problem Viewing & Accessing Hidden Folders Vista file management
Viewing jpgs in my folders Vista music pictures video
