Vista - LCD Monitor Refresh Rates
Old 09-04-2006   #1 (permalink)
Zak Humphries
Hi All,
I wonder if anyone can help. I am unable to set my widescreen monitor to
1680x1050, the option is available but only with a refresh rate of 75Hz
which it cant do. At lower resolutions the 60Hz option shows up. I have
tried this with both the microsoft driver, and the nvidia driver, also with
the generic plug and play monitor, and a windows xp inf for my monitor. Any
ideas?
Cheers
Zak
Old 09-04-2006   #2 (permalink)
hb
Re: LCD Monitor Refresh Rates
> ideas?
Check the monitor instructions for the "native resolution" and run it
thusly. Ignore the refresh rate on LCD monitors.
Old 09-04-2006   #3 (permalink)
Zak Humphries
The native resolution is 1680x1050x60 (works perfectly under XP) its only in
vista rc1 that I am FORCED into a 75Hz refresh rate which the monitor cant
handle.
Cheers
"hb" <dev@null.invalid> wrote in message
news:OoCn$mF0GHA.4116@TK2MSFTNGP02.phx.gbl...
>> with
>> Any
>> ideas?
Old 09-05-2006   #4 (permalink)
**__Mike__**
Try Display Settings->Advanced Settings->List All Modes
If it's not there, I believe it means the driver is telling Windows that the
video card does not support it.
-Mike
"Zak Humphries" <zhumphries@hotmail.com> wrote in message
news:uJt9XqF0GHA.4368@TK2MSFTNGP02.phx.gbl...
> in vista rc1 that I am FORCED into a 75Hz refresh rate which the monitor
> cant handle.
> Cheers
>>> with
>>> Any
>>> ideas?
Progam for custom refresh rates ? Software
Video Refresh Rates Vista hardware & devices
Gadget Refresh Rates Vista General
Force Monitor refresh rate Vista General
GeForce5700LE and Refresh Rates Vista hardware & devices
