Vista Tutorial - Backup system, home premium?
Old 05-10-2008   #1 (permalink)
Sven Pran
Guest
I am looking for a means to create system backup of my Vista Home premium
version in case I shall ever have to reinstall the system, for instance on a
new harddisk.
The backup help on my system tells me that the tool for this task is a "PC
Complete backup", but also that this is not available on Vista home
versions.
Apparently this system backup must be burned on a CD (or DVD), but where can
I find a utility that does just that?
regards Sven
Old 05-10-2008   #2 (permalink)
Not Me
Guest
Re: Backup system, home premium?
Many people recommend Acronias True Image, others say use Ghost.
A Professional Amateur...If anyone knew it all, none of would be here!
CarGodZeroOne@xxxxxx
Change Alpha to Numeric to reply
"Sven Pran" <no.direct@xxxxxx> wrote in message
news:edo3v3ssIHA.3716@xxxxxx
> a new harddisk.
> versions.
> can I find a utility that does just that?
> regards Sven
Old 05-11-2008   #3 (permalink)
Huib
Guest
I am using the Vista back-up one and it is working very good.
You can get it via confiuration screen / back-up centrum or via
computer/right mouse click on the disk / requirements and tab Extra
It is correct, the first time it makes and full back-up on the medium you
choose (it do it on and external HDD), the other times it is and incremental
back-up.
Restoring maps our looking for individual files works perfect so i don't see
why to use third party SW which are creating only risks to make your system
unstable.
The only problem is once you choose and other medium our time its starts all
over again with a full back-up.
When i perform a back-up on a DVD (only 6 monthly) and switch than back to
the HDD it is starting againg with a full back-up, with third party SW - you
can make your choose of couse...
You can als take a fix day to start automatically a back (incremental) ...
Success
Huib
"Sven Pran" <no.direct@xxxxxx> schreef in bericht
>a new harddisk.
> versions.
> regards Sven
Old 05-11-2008   #4 (permalink)
Sven Pran
Guest
Yes, I am aware of the Vista backup, but that is not sufficient if (as I
have experienced) the entire harddisk is destroyed and must be replaced.
In that case the "normal" procedure seems to be that you take the original
system recovery CD that came with your machine and re-install the system.
Yhen you have to go through all the updates that have occurred for that
system and you have to reconfigure your system, And now at last can you get
your machine back to life with your applications backup.
What I am looking for is some means to create a "system recovery CD" which
when used will immediately restore (or create) my system according to the
state at the time I created that CD, which of course will be whenever I know
that there has been a substantial change to my system from last time I did
this job.
Then I shall be happy to use Vista backup for my applications.
On my last XP-machine I have used Ghost to create an image of the harddisk
at regular intervals. When I recently had a complete harddisk failure I
tried to boot from this image. The boot process proceeded until I had the
Windows XP logo displayed on the screen but I never got the user logos so I
was unable to log on to the system. I suspect this had to do with the fact
that the boot was from the image disk on E: and that the image included some
(critical) references to C: which of course at that time was empty.
regards Sven
"Huib" <anonymous@xxxxxx> wrote in message
news:4826a35f$0$2950$ba620e4c@xxxxxx
Quote:
> Hi,
> incremental back-up.
> see why to use third party SW which are creating only risks to make your
> system unstable.
> all over again with a full back-up.
> you can make your choose of couse...
> Success
> Huib
>>a new harddisk.
>> "PC Complete backup", but also that this is not available on Vista home
>> versions.
>> regards Sven
Backup on 64-bit Vista Home Premium Vista General
Cannot backup to NAS from Win Vista x64 Home Premium. Vista networking & sharing
Vista Home Premium Backup Vista General
Home premium system backup? Vista General
Home Premium Backup and reccomendations Vista General
